Multiple/broken/repeated listings in Search results
Jul 14, 2008 Jul 14, 2008
Hi, I recently switched from RH 6 to RH 7 and when I generate a project, I'm now getting multiple repeats in my search results. For example, if I did a search on "Laboratory processes," it will appear three (or more) times in my search list (though not all bunched together). One of those links will take me to the right place. The others will have the "You've reached a broken link" page. I've already gone through and fixed *all* broken links in the document. RoboHelp even says there are no broken links. What could be causing this? I already read the "Multiple search results" topic on here, and this is *not* my issue. Any responses will be appreciated!
~ Heather in NC
1.7K
Guest
Just for giggles, Heather (and I think it may very well solve the problem...), make a backup of your project, then rename the CPD file and reenter your project. I think the CPD data got scrambled in the upgrade, or was already scrambled and didn't complain until the upgrade. I'll bet you a cookie this fixes it.
Good luck!
Um, what's a CPD file? 🙂
Guest
The CPD file is in your project directory. For example, if your project is called Accounting, the file to look is Accounting.cpd. Make a complete project backup, rename or delete the CPD file, and open the project again.
The CPD file is a database, sorta, that keeps track of where everything is in your project. It's a little cranky, and every once in a while has to be reindexed (renamed) to cure any one of a host of neuroses.
Hi all
Laurin, thanks for the chuckle. You are correct in that the CPD file is a database. And that's precisely what it is! It's a Microsoft Access database. These normally have a file extension of .MDB. RoboHelp HTML used to use these with a custom extension of .MPJ. Then things changed and XML entered the picture. Hence the change to .XPJ. But the .MPJ file is still around. He just had his name changed. He is now known as the .CPD. I'm speculating a bit on this, but I believe the .CPD means "Cache Project Database.
Cheers... Rick
Sadly, this didn't change anything. I opened Exporer, right-clicked on the project folder, made a copy, pasted it into the directory. Then I opened the "real" project folder, changed the CPD file name to "Test" (just to change it to something), closed Explorer, and opened the project in RH. Ran the compiler and... same deal.
Guest
<<I opened Exporer, right-clicked on the project folder, made a copy, pasted it into the directory. >> Does this mean that you copied the project back into itself? I hope not...
As for the rename - did you change the file name or the extension?
I should have been more clear.
First, make a complete copy of your project, and save it somewhere else. Far away.
Then, rename <<project>>.cpd to <<project>>.bad. Or old. Or yuck. Whatever. But rename the extension.
If you didn't do this, try again. I might just be misunderstanding your last reply, so feel free to clarify.
Enthusiast ,
Hi, Heather,
Here's another thread that discusses the same issue:
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=65&catid=450&threadid=1362525
In that case — and this is the usual reason why the results of a search contain duplicated and broken entries — the writer had inavertently created some hyperlinks to topics that were above the root folder of the help project.
Pete
Hi, I had indeed changed the name of the file, not the extension. I tried that, changing it to "BAD" and had no change. No worries- I did not save the folders inside the folders. They are separate folders (though they're not far, far away). We're working off the C: drive here, but everything has its own folder.
I don't undestand the whole root/upstream thing, or how I know if something's out of the root. Or where I'd look to see where else it would be or how it would have gotten there. Thanks for hanging in.
Guest
ok, let's back up a little. You say you came up from RH6 to RH7. Everything worked well back in 6... did you make any other changes as you migrated up to 7? I didn't get a sense of that, which is why I didn't start with investigating paths and such.
Nope, no other changes. And weirdly, out of 7 projects, this is the only one this is happening in. Albeit, it's the biggest one we have.
Guest
both these facts - there were no other changes (file/project name or location, etc.) and that it only happens on one project still point me towards the CPD file. But that's just me - maybe someone else has some ideas.
Question: The first time you tried the rename, we know now that you left the cpd extension. So, on the second attempt, did you work with the same group of project files, or revert back to your original project as saved in your backup?
If you worked with the same fileset, I would restore my backup, to be back at the very beginning, and rename the cpd file extension (or really, you can just delete it...) and try opening the project again, while waiting for some more guidance.
Thanks. I'm home now with two strikes against me- dial-up AND no RoboHelp, so I'll try these things in the morning.
Guest
lucky you! I'm still at work, with two chms to whip out before I leave.
Zzzzzzzz.....
Jul 15, 2008 Jul 15, 2008
I deleted the CPD file as recommended. But everytime the file compiles, it generates a new one. And... same result. (Multiple/broken search entries.)
Guest
Yes, the CPD is supposed to rebuild - so that's a good thing. And now, we can rule that out as being the problem.
Valorous Hero ,
Heather, have you explored the option Pete popped in to suggest? If not, you really should investigate.
Thanks RoboWizard. As I posted after Pete's post, I don't understand how to figure out if something is "above" or out of the root or any of that. I don't SEE anything outside the folder, but I don't really know what to look for.
Valorous Hero ,
Hi again Heather
This could prove to be a bit on the tricksy side. Here's why. RoboHelp HTML has traditionally presented dialogs we may see from time to time that advise us when things like this are outside the project. The problem with this is that the dialogs also offer a nifty little check box that says "Don't show this again". And if you were to click and place a check mark inside the check box, you quite literally will never see the dialog again. And there is no simple way to get it back. You have to edit your Windows Registry.
The bottom line here is that you have some investigative work to do to determine where these references are coming from. Perhaps try clicking Tools > Reports > Missing Topic References as a start.
Cheers... Rick
That HAS happened! I DO remember that message, about things being outside the project, esp having to do with some blue bullets I am using. There have been a few other files that popped up with too. Oh man. I bet that is it. I hear you're never to touch the Registry!
Oh darn, I don't have any missing topic references.
Valorous Hero ,
Hi Heather
Do you have another author there? Any way to open this project on a different PC? My thinking here is as follows.
If you are hesitant to edit the registry, this might show up on a different PC.
If you want to try and edit the registry (it's not really that bad) take a look at fellow Adobe Community Expert Peter Grainge's site at the link below and explore Snippet 13.
http://www.grainge.org/pages/snippets/snippets.htm
What is this output type?
Cheers... Rick
Guest
question - are you compiling a chm file, or are you generating and publishing a web-based WebHelp system?
Cuz if you are publishing to the web, I wonder if you could go into Windows Explorer, BACKUP the current folder set for the published Help, then delete it entirely from its standard location - and publish again to put a fresh project out there. Maybe there is some junk left over from older iterations?
Anyone see any problems with that?
It's both. We publish in both CHM and WebHelp. I do a batch generate usually, but in this case, I've just been doing the CHM file and it's still having the issues.
FYI- when you use terms like "backup the current folder"... I'm not sure many people really get that. To me, it means "make a copy of it" and that's what I do. So right now in my documents tree, I've got the regular folder and then the "Copy of regular folder" etc. If you mean something different, please elaborate.
Thanks for continuing on the case.
No other authors, no other RH users. Just me. No way to open it on any other computer. I am SURE this has SOMETHING to do with the move from RH 6 to RH 7, even though it didn't affect the other files. I'm going to pass on anything to do with the Registry.
Output type is CHM and WebHelp. The multiple search results occur in both formats.
RoboHelp Documentation
Download Adobe RoboHelp
