Why is Cold Fusion 2016 taking so long to start
Oct 24, 2016 Oct 24, 2016
After server reboot sometimes cold fusion application services takes up to 24 hours to start.  I check with netstat -a -n -o and neither port 8500 or 8016 are listening.  inside the command prompt,  I run the cfstop and cfstart bat and the application starts but the services still say they are stopped or starting.
When I try to manually start the cold fusion application in "services", I get an error message
897
Guide ,
Perhaps there are some details about the CF start up in logs. Check ColdFusion2016\cfusion\logs coldfusion-error.log coldfusion-out.log for errors, warnings or maybe something timing out.
I guess that is Windows, so perhaps add some details about what version and 32 64 bit. If not indicate OS details.
HTH, Carl.
Oct 27, 2016 Oct 27, 2016
Information from coldfusion-error log of last slow startup.  I am not sure what all of this means.  Beside that there look like there could be a memory leak with Tomcat.
Oct 21, 2016 5:11:06 PM org.apache.catalina.core.StandardServer await
INFO: A valid shutdown command was received via the shutdown port. Stopping the Server instance.
Oct 21, 2016 5:11:06 PM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-nio-8500"]
INFO: Pausing ProtocolHandler ["ajp-nio-8016"]
Oct 21, 2016 5:11:06 PM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service Catalina
Oct 21, 2016 5:11:14 PM org.eclipse.jetty.server.AbstractConnector doStop
INFO: Stopped ServerConnector@4db3d0ce{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
Oct 21, 2016 5:11:14 PM org.eclipse.jetty.server.handler.ContextHandler doStop
INFO: Stopped o.e.j.s.ServletContextHandler@3ad7eb4a{/,null,UNAVAILABLE}
Oct 21, 2016 5:11:14 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477081542123,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=25,SECOND=42,MILLISECOND=123,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.runtime.Cast$1] (value [coldfusion.runtime.Cast$1@32bdb86e]) and a value of type [java.lang.Boolean] (value [true]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477084100801,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=5,HOUR_OF_DAY=17,MINUTE=8,SECOND=20,MILLISECOND=801,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477083120311,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=52,SECOND=0,MILLISECOND=311,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477081713402,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=28,SECOND=33,MILLISECOND=402,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 21, 2016 5:11:15 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477083133181,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=52,SECOND=13,MILLISECOND=181,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477079206604,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=3,HOUR_OF_DAY=15,MINUTE=46,SECOND=46,MILLISECOND=604,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1423976400000,areFieldsSet=true,areAllFieldsSet=false,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=?,YEAR=2015,MONTH=1,WEEK_OF_YEAR=?,WEEK_OF_MONTH=?,DAY_OF_MONTH=15,DAY_OF_YEAR=?,DAY_OF_WEEK=?,DAY_OF_WEEK_IN_MONTH=?,AM_PM=?,HOUR=?,HOUR_OF_DAY=?,MINUTE=?,SECOND=?,MILLISECOND=?,ZONE_OFFSET=?,DST_OFFSET=?]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477079240005,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=3,HOUR_OF_DAY=15,MINUTE=47,SECOND=20,MILLISECOND=5,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477081568223,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=26,SECOND=8,MILLISECOND=223,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 21, 2016 5:11:15 PM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-nio-8500"]
INFO: Stopping ProtocolHandler ["ajp-nio-8016"]
Exception in thread "Thread-27" java.lang.NoClassDefFoundError: java/lang/Thread$State
at org.apache.axis2.engine.ListenerManager.stop(ListenerManager.java:195)
at org.apache.axis2.engine.ListenerManager$ListenerManagerShutdownThread.run(ListenerManager.java:315)
Caused by: java.lang.ClassNotFoundException: java.lang.Thread$State
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at coldfusion.bootstrap.BootstrapClassLoader.loadClass(BootstrapClassLoader.java:226)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 2 more
Oct 21, 2016 5:33:58 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\ColdFusion2016\cfusion\lib;C:\ColdFusion2016\cfusion\jintegra\bin;C:\ColdFusion2016\cfusion\jintegra\bin\international;C:\ColdFusion2016\cfusion\lib\oosdk\classes\win
Oct 21, 2016 5:34:01 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-8500"]
Oct 21, 2016 5:34:02 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
INFO: Using a shared selector for servlet write/read
Oct 21, 2016 5:34:02 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["ajp-nio-8016"]
Oct 21, 2016 5:34:02 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Oct 21, 2016 5:34:02 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/8.0.32
Oct 21, 2016 5:34:13 PM org.apache.jasper.servlet.TldScanner scanJars
INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Oct 21, 2016 5:43:19 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Oct 21, 2016 5:43:20 PM org.apache.coyote.AbstractProtocol init
Oct 21, 2016 5:43:21 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
Oct 21, 2016 5:43:21 PM org.apache.coyote.AbstractProtocol init
Oct 21, 2016 5:43:21 PM org.apache.catalina.core.StandardService startInternal
Oct 21, 2016 5:43:21 PM org.apache.catalina.core.StandardEngine startInternal
Oct 21, 2016 5:43:29 PM org.apache.jasper.servlet.TldScanner scanJars
Oct 21, 2016 5:43:32 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [3,120] milliseconds.
Oct 21, 2016 5:43:40 PM org.apache.catalina.core.ApplicationContext log
INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 25.72-b15
Oct 21, 2016 5:57:13 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Oct 21, 2016 5:57:15 PM org.apache.coyote.AbstractProtocol init
Oct 21, 2016 5:57:16 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
Oct 21, 2016 5:57:16 PM org.apache.coyote.AbstractProtocol init
Oct 21, 2016 5:57:16 PM org.apache.catalina.core.StandardService startInternal
Oct 21, 2016 5:57:16 PM org.apache.catalina.core.StandardEngine startInternal
Oct 21, 2016 5:57:25 PM org.apache.jasper.servlet.TldScanner scanJars
Oct 21, 2016 5:57:27 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [1,263] milliseconds.
Oct 21, 2016 5:57:28 PM org.apache.catalina.core.ApplicationContext log
Oct 21, 2016 7:40:17 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Oct 21, 2016 7:40:19 PM org.apache.coyote.AbstractProtocol init
Oct 21, 2016 7:40:20 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
Oct 21, 2016 7:40:20 PM org.apache.coyote.AbstractProtocol init
Oct 21, 2016 7:40:20 PM org.apache.catalina.core.StandardService startInternal
Oct 21, 2016 7:40:20 PM org.apache.catalina.core.StandardEngine startInternal
Oct 21, 2016 7:40:27 PM org.apache.jasper.servlet.TldScanner scanJars
Oct 21, 2016 7:40:56 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [29,033] milliseconds.
Oct 21, 2016 7:40:57 PM org.apache.catalina.core.ApplicationContext log
Oct 21, 2016 7:41:29 PM org.eclipse.jetty.util.log.Log initialized
INFO: Logging initialized @79830ms
Oct 21, 2016 7:41:31 PM org.eclipse.jetty.server.Server doStart
INFO: jetty-9.3.6.v20151106
Oct 21, 2016 7:41:31 PM org.eclipse.jetty.server.handler.ContextHandler doStart
INFO: Started o.e.j.s.ServletContextHandler@7694e93d{/,null,AVAILABLE}
Oct 21, 2016 7:41:31 PM org.eclipse.jetty.server.AbstractConnector doStart
INFO: Started ServerConnector@3d5bfe2c{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
INFO: Started @82026ms
Oct 21, 2016 7:41:34 PM org.apache.catalina.core.ApplicationContext log
INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
Oct 21, 2016 7:41:44 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-8500"]
INFO: Starting ProtocolHandler ["ajp-nio-8016"]
Oct 21, 2016 7:41:44 PM com.adobe.coldfusion.launcher.Launcher run
INFO: Server startup in 89883 ms
Oct 22, 2016 11:46:11 PM org.apache.catalina.core.StandardServer await
Oct 22, 2016 11:46:11 PM org.apache.coyote.AbstractProtocol pause
Oct 22, 2016 11:46:11 PM org.apache.catalina.core.StandardService stopInternal
Oct 22, 2016 11:46:18 PM org.eclipse.jetty.server.AbstractConnector doStop
INFO: Stopped ServerConnector@3d5bfe2c{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
Oct 22, 2016 11:46:18 PM org.eclipse.jetty.server.handler.ContextHandler doStop
INFO: Stopped o.e.j.s.ServletContextHandler@7694e93d{/,null,UNAVAILABLE}
Oct 22, 2016 11:46:18 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.runtime.Cast$1] (value [coldfusion.runtime.Cast$1@6c32fe09]) and a value of type [java.lang.Boolean] (value [true]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477189507017,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=25,SECOND=7,MILLISECOND=17,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477189885347,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=31,SECOND=25,MILLISECOND=347,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477183874888,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=8,HOUR_OF_DAY=20,MINUTE=51,SECOND=14,MILLISECOND=888,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477191360946,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=56,SECOND=0,MILLISECOND=946,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 22, 2016 11:46:19 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477190161587,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=36,SECOND=1,MILLISECOND=587,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477186631156,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=9,HOUR_OF_DAY=21,MINUTE=37,SECOND=11,MILLISECOND=156,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477186687209,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=9,HOUR_OF_DAY=21,MINUTE=38,SECOND=7,MILLISECOND=209,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477190420775,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=40,SECOND=20,MILLISECOND=775,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477194259022,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=11,HOUR_OF_DAY=23,MINUTE=44,SECOND=19,MILLISECOND=22,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477190472647,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=41,SECOND=12,MILLISECOND=647,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477161431358,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=2,HOUR_OF_DAY=14,MINUTE=37,SECOND=11,MILLISECOND=358,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477161432575,areFieldsSet=true,areAllFieldsSet=true,lenient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,startMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth=10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInFirstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=2,HOUR_OF_DAY=14,MINUTE=37,SECOND=12,MILLISECOND=575,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 22, 2016 11:46:19 PM org.apache.coyote.AbstractProtocol stop
... 2 more
Oct 22, 2016 11:46:34 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Oct 22, 2016 11:46:35 PM org.apache.coyote.AbstractProtocol init
Oct 22, 2016 11:47:16 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
Oct 22, 2016 11:47:16 PM org.apache.coyote.AbstractProtocol init
SEVERE: Failed to initialize end point associated with ProtocolHandler ["ajp-nio-8016"]
java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Unknown Source)
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:340)
at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:742)
at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:458)
at org.apache.catalina.connector.Connector.initInternal(Connector.java:960)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102)
at org.apache.catalina.core.StandardService.initInternal(StandardService.java:568)
at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:851)
at com.adobe.coldfusion.launcher.Launcher.run(Launcher.java:1005)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.adobe.coldfusion.bootstrap.Bootstrap.init(Bootstrap.java:100)
at com.adobe.coldfusion.bootstrap.Bootstrap.main(Bootstrap.java:185)
Oct 22, 2016 11:47:16 PM org.apache.catalina.core.StandardService initInternal
SEVERE: Failed to initialize connector [Connector[AJP/1.3-8016]]
org.apache.catalina.LifecycleException: Failed to initialize component [Connector[AJP/1.3-8016]]
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:107)
Caused by: org.apache.catalina.LifecycleException: Protocol handler initialization failed
at org.apache.catalina.connector.Connector.initInternal(Connector.java:964)
... 11 more
Caused by: java.net.BindException: Address already in use: bind
... 12 more
Oct 22, 2016 11:47:16 PM org.apache.catalina.core.StandardService startInternal
Oct 22, 2016 11:47:16 PM org.apache.catalina.core.StandardEngine startInternal
Oct 22, 2016 11:47:20 PM org.apache.jasper.servlet.TldScanner scanJars
Oct 22, 2016 11:47:21 PM org.apache.catalina.core.ApplicationContext log
INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 25.112-b15
Oct 22, 2016 11:47:33 PM org.eclipse.jetty.util.log.Log initialized
INFO: Logging initialized @68753ms
Oct 22, 2016 11:47:35 PM org.eclipse.jetty.server.Server doStart
Oct 22, 2016 11:47:36 PM org.eclipse.jetty.server.handler.ContextHandler doStart
INFO: Started o.e.j.s.ServletContextHandler@30656e1c{/,null,AVAILABLE}
Oct 22, 2016 11:47:36 PM org.eclipse.jetty.server.AbstractConnector doStart
INFO: Started ServerConnector@884e63{HTTP/1.1,[http/1.1]}{0.0.0.0:51960}
Oct 22, 2016 11:47:36 PM org.eclipse.jetty.server.Server doStart
INFO: Started @71650ms
Oct 22, 2016 11:47:39 PM org.apache.catalina.core.ApplicationContext log
Oct 22, 2016 11:47:45 PM org.apache.coyote.AbstractProtocol start
Oct 22, 2016 11:47:45 PM com.adobe.coldfusion.launcher.Launcher run
INFO: Server startup in 75022 ms
Oct 22, 2016 11:47:45 PM org.apache.catalina.core.StandardServer await
SEVERE: StandardServer.await: create[localhost:8011]:
java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(Unknown Source)
at java.net.AbstractPlainSocketImpl.bind(Unknown Source)
at java.net.PlainSocketImpl.bind(Unknown Source)
at java.net.ServerSocket.bind(Unknown Source)
at java.net.ServerSocket.<init>(Unknown Source)
at org.apache.catalina.core.StandardServer.await(StandardServer.java:421)
at com.adobe.coldfusion.launcher.Launcher.await(Launcher.java:1419)
at com.adobe.coldfusion.launcher.Launcher.access$000(Launcher.java:135)
at com.adobe.coldfusion.launcher.Launcher$1.run(Launcher.java:1103)
at java.lang.Thread.run(Unknown Source)
Oct 22, 2016 11:47:45 PM org.apache.coyote.AbstractProtocol pause
Oct 22, 2016 11:47:45 PM org.apache.catalina.core.StandardService stopInternal
Oct 22, 2016 11:47:52 PM org.eclipse.jetty.server.AbstractConnector doStop
INFO: Stopped ServerConnector@884e63{HTTP/1.1,[http/1.1]}{0.0.0.0:51960}
Oct 22, 2016 11:47:52 PM org.eclipse.jetty.server.handler.ContextHandler doStop
INFO: Stopped o.e.j.s.ServletContextHandler@30656e1c{/,null,UNAVAILABLE}
Oct 22, 2016 11:47:53 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.runtime.Cast$1] (value [coldfusion.runtime.Cast$1@173650b2]) and a value of type [java.lang.Boolean] (value [true]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [org.apache.axis.utils.XMLUtils.ThreadLocalDocumentBuilder] (value [org.apache.axis.utils.XMLUtils$ThreadLocalDocumentBuilder@78014c7f]) and a value of type [org.apache.xerces.jaxp.DocumentBuilderImpl] (value [org.apache.xerces.jaxp.DocumentBuilderImpl@5d17300d]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1b412d49]) and a value of type [flex.compiler.ConsoleOutputHandler] (value [flex.compiler.ConsoleOutputHandler@365e38fb]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@444ee8fb]) and a value of type [flex.util.ServletPathResolver] (value [flex.util.ServletPathResolver@20bd2f27]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [ROOT] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@3284651c]) and a value of type [java.util.WeakHashMap] (value [{class javax.xml.bind.annotation.W3CDomHandler=public javax.xml.bind.annotation.W3CDomHandler()}]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Oct 22, 2016 11:47:53 PM org.apache.coyote.AbstractProtocol stop
Exception in thread "Thread-26" java.lang.NoClassDefFoundError: java/lang/Thread$State
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 2 more
Oct 23, 2016 9:20:27 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Oct 23, 2016 9:20:28 PM org.apache.coyote.AbstractProtocol init
Oct 23, 2016 9:20:30 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
Oct 23, 2016 9:20:30 PM org.apache.coyote.AbstractProtocol init
Oct 23, 2016 9:20:30 PM org.apache.catalina.core.StandardService startInternal
Oct 23, 2016 9:20:30 PM org.apache.catalina.core.StandardEngine startInternal
Oct 23, 2016 9:20:37 PM org.apache.jasper.servlet.TldScanner scanJars
Oct 23, 2016 9:20:38 PM org.apache.catalina.core.ApplicationContext log
Oct 23, 2016 9:20:56 PM org.eclipse.jetty.util.log.Log initialized
INFO: Logging initialized @37176ms
Oct 23, 2016 9:20:57 PM org.eclipse.jetty.server.Server doStart
Oct 23, 2016 9:20:58 PM org.eclipse.jetty.server.handler.ContextHandler doStart
INFO: Started o.e.j.s.ServletContextHandler@6d769efb{/,null,AVAILABLE}
Oct 23, 2016 9:20:58 PM org.eclipse.jetty.server.AbstractConnector doStart
INFO: Started ServerConnector@627c9d8c{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
Oct 23, 2016 9:20:58 PM org.eclipse.jetty.server.Server doStart
INFO: Started @39206ms
Oct 23, 2016 9:21:00 PM org.apache.catalina.core.ApplicationContext log
Oct 23, 2016 9:21:08 PM org.apache.coyote.AbstractProtocol start
Oct 23, 2016 9:21:08 PM com.adobe.coldfusion.launcher.Launcher run
INFO: Server startup in 44220 ms
Adobe Employee ,
Oct 26, 2016 Oct 26, 2016
Can you please launch command prompt as Run as Admin and start ColdFusion service with this command.
>> cfstart > start.log, once ColdFusion starts properly, please share the logs here. let's see what is wrong in it.
Log location: \ColdFusion2016\cfusion\bin
Priyank
Priyank Shrivastava
Since this server is in production, I will have to wait until the weekend to get that start log information for you because it can sometimes take up to two days before coldfusion starts after it is stopped.
Adobe Employee ,
Please try this, clear the classes from cfclasses folder.
Location: \ColdFusion\cfusion\wwwroot\WEB-INF\cfclasses.
Priyank
Priyank Shrivastava
Can this be done while the server is in production? Or must it be done after hours?
Adobe Employee ,
You can clear the classes while ColdFusion is running, but if you want to try this after hours that would be fine.
Priyank
Priyank Shrivastava
Documentation
