CFFORM - field focus
Enthusiast ,
Jul 15, 2008 Jul 15, 2008
I am using CFFORM to create a form including a CFCALENDAR, the problem I have is that the first field which is a text field (name: FN) is not focused.
I added this code to the BODY tag, and the name matches the name of the CFFORM (checkform), yet the FN field will not function
onload="document.checkform.fn.focus();"
Appreciate any help
Mark
Advanced techniques
916
Enthusiast , Jul 15, 2008 Jul 15, 2008
thanks, your solution worked... however it did not at first... then I noticed, the BODY tag had a DIV after it right next to it, I was dropping the ONLOAD into the DIV...duhhhhh.. one of those things you stare at for hours and can't see the wood for the trees!
Thanks for the help
Mark,
The input name/id (FN) needs to be the same case as the onload call.
So if the input is FN the onload would look like this:
onload="document.checkform.FN.focus();"
Ken Ford
Adobe Community Expert - Dreamweaver/ColdFusion
Fordwebs, LLC
http://www.fordwebs.com
"ACS LLC" <webforumsuser@macromedia.com> wrote in message news:g5iq1v$a48$1@forums.macromedia.com...
> Appreciate any help
> Mark
Enthusiast ,
I double checked the code and they are both in lower case
Enthusiast ,
Just a thought, for the text input, I'm using this, should I be using CFINPUT??
<input type="text" name="fn" size="15" maxlength="25" style="background-color: #CCE5FF;
border-width: 1px; border-color: #000000; color: black; font-size: 20pt;">
cfinput or input does not matter.
add an ID attribute to your input field, with same value ('fn')...
make sure checkform is in correct case as well...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Enthusiast ,
Yep. it's all in lowercase. I added the ID="fn" to the input text field... still doesn't work :(
your form is not inside an iframe or a cfwindow or some other element
per chance?
try using document.getElementById("fn").focus() instead of
document.checkform...
i am running out of ideas here... :)
Azadi Saryev
Sabai-dee.com
Enthusiast ,
nope, nothing weird going on at all, straight code.
I've never used CFFORM, always just FORM, and it worked fine, so I thought it must be something to do with that
How do I utilize the document.getElementById("fn").focus() ?
Mark
put into a function in the page's HEAD and call the function form the
BODY's onload event:
<script>
setFocus = function(){
document.getElementById("fn").focus();
</script>
<body onload="setFocus()">
make sure your fn input field has an ID="fn" attribute.
Azadi Saryev
Sabai-dee.com
Enthusiast ,
Thanks for the help
happens to me all the time... glad you got it sorted out!
Azadi Saryev
Sabai-dee.com
Documentation
