How to find a variable just after a marker?
Oct 27, 2016 Oct 27, 2016
Dear experts,
My project steps further - but as soon as I have to deal with FM-objects I still struggle. The script should do this:
  • In the document (http://www.daube.ch/zz_tests/Markers-and-variables.fm) there are markers of type #calc (which are all found and stored into an array.
  • Some of them are immediately followed by a variable (called temporary variable, because the names are built by date/time).
  • Before I insert the new variable, the old one should be found and removed.
  • The problem is that I do not find the old variable and hence can not remove it, before the new one is inserted. The inserting is OK, but it occurs independently of existing variables.
  • Line 49 always evaluates to false, even if there is a variable present.
How can I find (at first hand) any variable (Later I will need to check whether it is really a temprary variable) ?
#target framemaker
// Required doc: Markers-and-variables.fm:
  aVariables = ["#DOCname", "#TEST", "2016-09-27T10:28:46.060Z"];
  goCurrentDoc =  app.ActiveDoc;
  giNCalcMarkers = CollectMarkers  (gaoCalcMarkers, "#calc");
for (j = 0; j < giNCalcMarkers; j++) {
  goCurrentMarker = gaoCalcMarkers;            // find a marker
  oFound = FindVariable (goCurrentDoc, goCurrentMarker);
  if (oFound[0]) {                                // true, variable found
    oFound[1].Delete();                           // remove temp. variable from document
  oTextLoc = goCurrentMarker.TextLoc;
  oTextLoc.offset = oTextLoc.offset + 1;          // insert temp variable behind marker
  InsertVariable (goCurrentDoc, oTextLoc, "#TEST", "\+1.275×10<super>\+9" );
// ================= Routines to be tested ========================================================
function CollectMarkers (aMarkers, sMarkerName) { //=== Collect marker-objects, store in array ====
// In        aMarkers:    global array of markers to be filled
//           sMarkerName: type of marker to be collected
// Out       Return number of markers collected
var  oMarker, MarkerTI, nMarkers;
  tsSave = goCurrentDoc.TextSelection;            // save current cursor location
  oMarker = goCurrentDoc.FirstMarkerInDoc;
  while (oMarker.ObjectValid()) {
    MarkerTI = oMarker.MarkerTypeId;
    if (MarkerTI.Name == sMarkerName) {
      aMarkers.push(oMarker);                     // store the marker objects
    oMarker = oMarker.NextMarkerInDoc;
  goCurrentDoc.TextSelection = tsSave;            // Restore cursor location
  nMarkers = aMarkers.length;
  return nMarkers;                                // number of markers in array
} //--- end CollectMarkers
function FindVariable (oDoc, oMarker) { //=== Find variable behind marker ========================
// In        oMarker: current marker
// Out       Function returns [true, found variable] or [false, loc behind the marker]
var tLoc1 = oMarker.TextLoc,
    tLoc2 = oMarker.TextLoc,                      // should be just behind the marker
    j, myTextRange, findParams, fRange, oTextItem, aVarsRange, nVars, thisVar;
  tLoc1.offset = tLoc1.offset + 1;
  tLoc2.offset = tLoc2.offset + 2;
  myTextRange  = new TextRange(tLoc1,tLoc2);
  oDoc.TextSelection = myTextRange;               // Does this hold a variable ?
  findParams= GetFindParamsVariable ("");         // search for any variable
  fRange = goCurrentDoc.Find  (tLoc1, findParams);// is a textrange
  if (fRange.beg.obj.ObjectValid()) {
    aVarsRange = goCurrentDoc.GetTextForRange (fRange, Constants.FTI_VarBegin);
    nVars = aVarsRange.length;
    for (j = 0; j < nVars; j++) {                   // loop should not be necessary
      oTextItem = aVarsRange;                    // superfluous ?
      thisVar = oTextItem.obj;                      // should contain only one variable
      return [true, thisVar];
  } else {
    return [false, tLoc1];
} //--- end FindVariable
function GetFindParamsVariable (sVarName) { //=== Set up parameters to Find variable ==============
// In        sVarName: variable type to be found
// Out       Returns parameters for the find function: no wrapping around ?
var findParams;
  findParams = AllocatePropVals (2);
  findParams[0].propIdent.num = Constants.FS_FindWrap ;
  findParams[0].propVal.valType = Constants.FT_Integer;
  findParams[0].propVal.ival = 0 ; // don't start at the beginning => seems to be 'nowrap'
  findParams[1].propIdent.num = Constants.FS_FindNamedVariable;
  findParams[1].propVal.valType = Constants.FT_String;
  findParams[1].propVal.sval = sVarName;
  return findParams;
} //--- end GetFindParams
function InsertVariable (oDoc, oTextLoc, sVarName, sContent) { //=== Insert variable at location =====
// In        oTextLoc: where to insert the variable
//           sVarName: name of the variable
//           sContent: content of the variable
var oVar;
  oVar = oDoc.NewAnchoredFormattedVar (sVarName, oTextLoc);
  oVar.Fmt = sContent;
Scripting
733
Enthusiast , Oct 28, 2016 Oct 28, 2016
  1.     propVal = new PropVal() ;
  2.     propVal.propIdent.num = Constants.FS_FindObject;
  3.     propVal.propVal.valType = Constants.FT_Integer;
  4.     propVal.propVal.ival = Constants.FV_FindAnyMarker ;
  5.     FindParams.push(propVal);
We discussed it some months ago.
Re: Find next marker
BTW: gaoCalcMarkers is undefined.
Enthusiast ,
Hi Klaus,
you can't use "find" with Constants.FS_FindNamedVariable and name = "" for any variable.
You have to use Constants.FS_FindObject and Constants.FV_FindAnyVariable.
cu in Stuttgart (tekom) ?
Thanks, Klaus, for the tip.
It is, however, not easy to find all necessary ingredients of the PropVals setup:
Is It (a):
  findParams[1].propIdent.num = Constants.FS_FindObject;
  findParams[1].propVal.valType = Constants.FV_FindAnyVariable;
  findParams[1].propVal.ival = 0;     // ???
or (b):
  findParams[1].propVal.sval = "";    // ???
With a) the variable far away is found (after the next marker)
With b) nothing is found (as I had it before your answr).
Whether the third item (ival/sval) is needed and what the necessary values are: I have not found any information about that in the FDK - not speak of ES-docu.
Information such as "Parmeter name = findParams, Data Type = PropVals, Option = No, Desctiption = A property list that specifies what to search for" is the end of the story. No indication at all, what to specify for PropVals!
I have also tinkered around a lot with the tLoc1.offset value to start the find operation: even if stepping back 5 from the marker location the variable behind the next (not the current) marker is found.
Stuttgart (tekom) ? - I will not attend: to many items on stack.
Klaus
Enthusiast ,
Thanks, now it works!
gaoCalcMarkers - undefined only in this snippet
I had used Find next marker as the base - but still was not clever enough.
Oct 29, 2016 Oct 29, 2016
To sum up, here the complete working example - needs a proper document.
#target framemaker
  oDoc =  app.ActiveDoc;
  oMarker = oDoc.FirstMarkerInDoc;
  while (oMarker.ObjectValid()) {                 // get markers in order of creation
    if (MarkerTI.Name == "#calc") {
      bFound = FindVariable (oDoc, oMarker);      // remove already existing variable
      if (bFound) {
        oTextLoc = oMarker.TextLoc;
        InsertVariable (oDoc, oTextLoc, "#TEST", "\+1.275×10<super>\+9" );
function FindVariable (oDoc, oMarker) { //=== Find variable behind marker and remove it ===========
// Out       Function returns true for found+removed variable
    iUnique1= oMarker.TextLoc.obj.Unique,         // ¶ of the marker
    myTextRange, findParams, fRange;
  tLoc2.offset = tLoc2.offset + 1;
  fRange = oDoc.Find  (tLoc1, findParams);        // finds variable
  if (fRange.beg.obj.ObjectValid()) {             // variable found ?
    if (fRange.beg.obj.Unique == iUnique1) {      // same ¶ as the marker ?
      if (fRange.beg.offset == tLoc1.offset+1) {  // TR =? variable behind marker
        oDoc.DeleteText(fRange);                  // Delete the selected Variable
        return true;
  return false;                                   // there was'nt a variableb
function GetFindParamsVariable () { //=== Set up parameters to Find a variable ====================
// Out       Returns parameters for the find method
var findParams = new PropVals() ;
  propVal.propVal.ival = Constants.FV_FindAnyVariable ;
  findParams.push(propVal);
  return findParams;
} //--- end GetFindParamsVariable
var oVar;
