W3C Validation, continued.
8. Line 134, Column 36: there is no attribute "FRAMEBORDER".
<frameset cols="100%,*" frameborder=no border=0>
You have used the attribute named above in your document, but
the document type you are using does not support that attribute for
this element. This error is often caused by incorrect use of the
"Strict" document type with a document that uses frames (e.g. you
must use the "Transitional" document type to get the "target"
attribute), or by using vendor proprietary extensions such as
"marginheight" (this is usually fixed by using CSS to achieve the
desired effect instead).
This error may also result if the element itself is not
supported in the document type you are using, as an undefined
element will have no supported attributes; in this case, see the
element-undefined error message for further information.
How to fix: check the spelling and case of the element and
attribute, (Remember XHTML is all lower-case) and/or check that
they are both allowed in the chosen document type, and/or use CSS
instead of this attribute. If you received this error when using
the <embed> element to incorporate flash media in a Web page,
see the FAQ item on valid flash.
9. Line 134, Column 46: there is no attribute "BORDER".
10. Line 134, Column 47: element "FRAMESET" undefined.
You have used the element named above in your document, but
the document type you are using does not define an element of that
name. This error is often caused by:
o incorrect use of the "Strict" document type with a document
that uses frames (e.g. you must use the "Frameset" document type to
get the "<frameset>" element),
o by using vendor proprietary extensions such as
"<spacer>" or "<marquee>" (this is usually fixed by
using CSS to achieve the desired effect instead).
o by using upper-case tags in XHTML (in XHTML attributes and
elements must be all lower-case).
11. Line 135, Column 13: there is no attribute "SRC".
<frame src="whnjs.htm">
12. Line 135, Column 24: element "FRAME" undefined.
13. Line 136, Column 40: "NORESIZE" is not a member of a
group specified for any attribute.
<frame src="whskin_blank.htm" noresize>
14. Line 136, Column 40: element "FRAME" undefined.
