I have a small ColdFusion widget which I am able to use to
collect RSS feeds and display them randomly. Everything is working
okay except for the discription. I am getting the same desdription
for each item with the same array key. I am only getting the first
one in the array. It is not looping properly to give me the correct
discription. The title is correct but not the description. I have
attached the Application.cfm page and the widget utility.cfm.
You can see what is coming back by looking at
http://newsite.websbygeorge.com/utility.cfm You can see a dump of the ARRAY APPLICATION.RSSFeed by
looking at
http://newsite.websbygeorge.com/test.cfm
Your test site is down. (The joys of posting a URL on a
forum.)
If you look at this:
<cfset RandomPick = RandRange(1,
Arraylen(VARIABLES.LocalRSS[RandomFeed].rss.channel.item))>
One would probably quess that
Arraylen(VARIABLES.LocalRSS[RandomFeed].rss.channel.item) is equal
to 1.
You should dump the result of
Arraylen(VARIABLES.LocalRSS[RandomFeed].rss.channel.item) and see
what the arraylen is.
Without seeing your XML it's hard to venture a guess.
