Hi Every one,
Can Anyone help me to done this
Actually Iwant to save a illustrator file to postscript file. i have tried with below script but i cant get Output
set filepath to "DistillerIHT:In:" as Unicode text
tell application "Finder"
--set cName to theC as string
end tell
tell application "Illustrator CS"
activate
--set thisDoc to current document
set user interaction level to never interact
set thisDoc to name of current document as text
set FullPath to filepath & thisDoc & ".ps"
--display dialog newFPath -- this was just to check the path
set ppdFileName to "Adobe PDF" as Unicode text
set postOpts to {class:postscript options, PostScript:level 2}
set jobOpts to {class:job options, print area:artboard bounds, print as bitmap:true, file path:FullPath}
set printOpts to {class:print options, job settings:jobOpts, postscript settings:postOpts, printer name:"Adobe Postscript® File", PPD name:ppdFileName}
print current document options printOpts without dialogs
end tell
My Error
Karthick
What if you do it manually ? Same error ?
Final file will be
Hi
I found most of this script here, changed a few things to suit your setup, I to get the same error, but managed to create a .ps file,
I had to run the script three times though to get the .ps file, first run produced TNAC error, second run produced a 300 error, then
on the third run a .ps file, really strange.
I always prefer to run a preset makes life easier, plus you could have a few presets and have a list thrown up to choose which one
you want to use.
So unless there's a fix for this, I can only suggest a different style of scripting or try calling a preset.
MacScripter / Adobe Illustrator CS (v 11.0.0) printing postscript via applescript
set cName to "DistillerIHT:In:"
tell application "Adobe Illustrator"
activate
set newF to name of current document
set newFPath to cName & newF & ".ps"
set jobOpts to {class:job options, print area:artboard bounds, print as bitmap:true, file path:newFPath}
print document 1 options printOpts --without dialogs
set user interaction level to interact with all
close thisDoc saving no
end tell
Thanks for your detailed information,
i am still getting TNAC error for all scripts including yours script, but you talk about presets can u draft a script with using presets to save postscript file may be thats useful.
even through i found another way online see below link...
https://acrobatusers.com/forum/printing-prepress/automation-convert-pdf-ps/
Karthick | Eagerly waiting for your response
