I recently took a course in After Effects and the last couple of days I've been really struggling to get to grips with it. My most recent problem is that when I type straight into the composition, my font (Avenir 35 Light) appears condensed/horizontally compressed for no reason that I can fathom.
How it looks:
How it's meant to look (ignore colour):
I was using the same proportion file yesterday and it was OK, and can't work out what I've done to make it like this. If anybody could enlighten me I'd be so grateful.
2 things come to mind:
1. you are probably working in non-square aspect ratio. check your composition settings and see that you are using a square pixel composition
it is recommended to work from within the presets, but a common mistake is to choose an HDV Preset instead of HDTV.
2. check your character panel and see that your settings are 100% for width and height
Check the scaling settings on the type palette and your composition pixel aspect ratio.
Mylenium
It was no 1! Thank you so much. Give me 5 mins and I'll come up with the next problem....
