I recently moved my LR folders to a different location on my HD. The process was simple, and there were no problems. However, now when I Import new images, I get this odd message: "The destination folder xxxxx is not available. Using "Pictures" folder instead." Screen shot attached.
Yes, that path no longer exists because I moved it. And the images in the new location are available from LR with no problems. Why is LR still holding onto that one folder? How can I stop this message?
Change the Destination folder in the Import dialog box. It's on the right hand side, under "Destination".
dj... you must have sent some positive vibes to my computer, 'cause I had already changed the destination folder several times, but still kept getting the message. But after reading your response, I did it again, and voila! It worked. No more message.
Thanks....
Yes, I used to be in The Beach Boys, I always sing "Good Vibrations"
Well, it's happening again, this time with a different folder (screen shot attached). And as before (see original post), it's a folder that no longer exists. I've changed the destination folder multiple times. This stopped the problem for a while, then it started again. Any ideas on how to get rid of this... for good?
Is this disk going to sleep, or having connection problems?
This problem still exists. I'm still getting a message about the Destination Folder that no longer exists. Any ideas on how to make this stop?
Interesting. You write that the problem still exists, but you didn't respond to my request for information.
