I've just become a contributor. So I've uploaded my photo', added keywords and set a title. Everything is fine so far but for some reason I can't find through the search system. Even if I type every keyword of that picture it won't show up. Instead it shows an "Image not found" message.
How come?
Thanks in advance,
Joost Bouwer
Thanks for writing. The search engine can take a while to update with new content. I was able to locate your approved images online. Your portfolio can be seen here: Joost | Adobe Stock
Kind regards,
Mat Hayward
Kind regards,
Mat Hayward
Similar problem here. Around how long does that usually take?
When searching for my images, they only show up when searching my name, not the description tags. Is there a reason for this?
Please share an example and I will take a look.
-Mat
My image, Intimate, when searching using words "corset," "sensual woman" or the title "intimate", I went through 5-20 pages of each search and it was not there. Am I just not searching far enough?
Try searching for it from within your portfolio. If it shows up with the appropriate keywords then yes, you are correct, you aren't searching far enough. If not then you may have a problem with indexing.
-Mat
If I understand correctly, searching "chantell Reid nature" or "chantell reid intimate" etc, the coordinating images do show up. So it is just a matter of not being relevant enough in the search and having to search numerous pages, otherwise.
Hi Mat,
i'm new to contributing with Adobe, if i search for the exact title of an image i uploaded a week ago (i think) 'blond brown eye boy' i search 11 pages with no joy. Is this just a case of server hasn't reached it yet or perhaps an indexing issue? Thanks for your help. Peter
I had images accepted with the keywords Malibu, California, El Matador State Beach,El Matador and yet when I search using those keywords none of my images appear. The search engine has zero results for El Matador
