Hello,
i have an object (Text box & rectangle white color) they are grouped and there is a background image, if you move that group, you can see background image through the text.
my problem is how to create such this effect.
when i ungroup that group the effect will disappear. and i can't create it again.
like the following
my ver: InDesign CC 2015
i uploaded innd file at the following link for check.
Hima
Hi Hima,
The Blog post that Peter linked to shows how to create the effect you are looking for, except that it works on the text frame itself, rather than cutting the text out of another rectangle. So what you could do, is to create a rectangular text box the size and shape you desire, then follow the instructions as in Peter's linked post (using the Effects panel), then adjust where your text sits in the box by going to OBJECT>TEXT FRAME OPTIONS, then adjusting the left, right, top and bottom insets to get the type to sit where you want.
Make the text in registration color and set the frame (whole object) to screen.
Willi,
If you mean "Superposition" (or "Eclaircir" too) in French, totally Yeap!
