Has anyone had issues with the update to 2017 version as my machine now keeps crashing?
Hi artibhartiya,
Is this with a new project or an updated one? If updated, try a new project.
Kevin
I am already in the process of moving everything across onto a new file. However you have to understand this is a MASSIVE set back in an already impending deadline, this sort of issue should not come up in the first place.
ADOBE DOESN'T CARE ABOUT YOUR DEADLINE.
HOW DID THE CUSTOMERS GET ROPED INTO PAYING MONEY TO BE BETA TESTERS?????
SAME HERE Crashes as soon as I import something.
They told someone else that's having the same problem in MU to "try a different OS"..... Really like we have all the money in the world to just go buy another Pc with a different OS on it just to try to see if it'll work??!! .. . Adobe should just do a rollback instead. like ASAP ADOBE....
Don't forget about all the time it takes us to load everything up and do their testing for them......
BETA2017​
You updated your editing software under those conditions?
I've got no quarrel with the call for Adobe to get it right the first time, every time, but as I live in the real world, I also can't ignore the sheer folly of what you've done here.
Bad move updating just before a deadline.
Happening to me also on a large project with Lumetri on master clips. Randomly crashes.
Error reports:
Faulting application name: Adobe Premiere Pro.exe, version: 11.0.0.154, time stamp: 0x580880fc
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
Exception code: 0xc0000409
Fault offset: 0x0000000000074a30
Faulting process id: 0x20e8
Faulting application start time: 0x01d2356740d8027f
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2017\Adobe Premiere Pro.exe
Faulting module path: C:\WINDOWS\SYSTEM32\MSVCR120.dll
Report Id: 0680d9a1-e7ef-468e-8309-44823f00c653
Faulting package full name:
Faulting package-relative application ID:
Faulting process id: 0x2c24
Faulting application start time: 0x01d23566957928bc
Report Id: 4ecaf08a-8173-46e1-840f-5fb8dc72c153
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00007ff500000001
Faulting process id: 0x137c
Faulting application start time: 0x01d2356420a85a17
Faulting module path: unknown
Report Id: 14e1211e-5aa9-4af9-8339-95f00732f4a9
Faulting module name: Backend.dll, version: 11.0.0.154, time stamp: 0x58085b22
Fault offset: 0x00000000007af695
Faulting process id: 0x1f60
Faulting application start time: 0x01d23562c97faf2b
Faulting module path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2017\Backend.dll
Report Id: ff8cb2be-7c6a-4054-8e69-ef4431228564
I'm running a well-spec'd machine. Asus X99A, 5820k, 32GB ram, GTX970, etc..
I have the same issue, a project built with 2016 keeps crashing on opening with v2017....HELP! Can we rollback?
Did you reboot computer before and after installing 2017?
Yes you can roll back.
If you removed previous version (best to leave it on your system) you can install it from the CC app.
I'm constantly crashing, and this is a new project on a brand new computer.
Deinstall all Adobe products
Use cleanertool
Install again.
Use the Adobe Creative Cloud Cleaner Tool to solve installation problems
It seems that all applications crash. Nice 2017 update.
Same problem. Except I can't even keep it open long enough to even TRY to open a file. The applications just tries to open... then crashes.
WTH!!
One thing I have noticed is that the crashes have to do both with Lumetri and markers. When I add markers, it will just randomly crash and it is a crap shoot on whether it is MSVCRT or LoggingSession.
I have only had one crash so far that actually performed a recover. all others ones just picked up where I left off.
Now AE is another story but I will post more in that forum.
Adobe doesn't care about your projects crashing or the fact you make a living off of their product. Not only does Premiere CC keep crashing on me and losing me hundreds of dollars, they charged me for Photoshop as well for no reason. I've been on the phone with these — for 24 hours, and they are just a greedy scam company who builds up a face and presents itself like something you can trust.
Moderator warning: Do not use profanity. It is against Adobe community guidelines.
I've had this issue before, as well. Make sure you have AutoSave on, just in case it keeps happening. Plus, make sure your projects are up-to-date to the 2017 version, and your computer hardware is good to run the software, and your RAM usage is down.
I just had to uninstall all my Adobe products (9/13/17). I did them one at a time and the machine continued to lockup at startup. Finally uninstalled creative cloud (think it freezes on it's update). Computer now functioning. Adobe needs to fix this!
What graphics card is everyone using?
I am have an NVIDIA GeForce 940 MX; running on a Win 10 HP laptop with 16 GB RAM; 64-bit;
Is that the problem?
I had a problem with Premiere crashing on export.
I solved this by turning off the GPU acceleration option under File > Project Settings > General > Video Rendering and Playback
In my case I then selected Mercury Playback Engine Software Only
.. and it worked though export times take longer.
