I am trying to find a Flash ".fla" file that has a specific .jpg image in the library. Is there any way to do a search of all my .fla files and come up with results based on the contents of the libraries within the .fla documents? I've tried looking through each file one by one but I just can't find the file I'm looking for. Kind of hard to explain and likely not possible, but I would appreciate any advice on my problem. Thanks!
you can use jsfl to do that.
Javascript search? How do I do that?
Is JSFL able to go through your hard drive, find FLAs, look into the package, then library, and decode the binary to find out if the library item had a certain name?
yes, you can search folders for file names, use that to access the document and then use the document refrence to search the library.
