I'm trying to convert a PDF file to Excel. The pdf file is 60 MB (under the 100 MB limit), and I get the error message "Conversion Failure". Would appreciate anyone's assistance? thx!
Please visit the following links which discusses the issue similar to yours:
why do i always get conversion failure when converting pdf files to xls in exportpdf program?
Could you try exporting pdf using this link: https://cloud.acrobat.com/exportpdf
Let me know the results.
Thank You,
Shivam
Shivam,
Thank you for responding to my question!
The two links did not provide an explanation for the conversion failure.
I had a chat session on Friday, and he indicated it may be an internet connection issue. I was on my work computer on Friday, and tried the conversion again yesterday on my home computer...and got the same conversion failure.
I used the cloud.acrobat.com/exportpdf link you sent, and tried the following:
Original file 60 MB = Conversion Failure
Reduced file to 15 MB = Conversion Failure
Reduced file to 4.5 MB = Conversion Failure
Reduced file to 2.3 MB = Successful Download
The FAQ indicates the file limitation is 100 MB. I don't want to split up the file into 2 MB segments. Can you please help?!
Thank you!
Brian
Hi brians54997802,
Have you tried converting other pdf files to Excel?
Try to convert other pdf file with file size near to 60-50 MB, and see if the conversion works.
Would it be possible for you to upload the file, and share the link with us?
Visit https://cloud.acrobat.com/send , click Add Files>select the files from your Computer>select the file>Open>click Create Link, when the link has been generated, share it via private message.
To send a private message, hover the mouse over my name name, and select Message.
I tried to convert a different file that is 36 MB...same "conversion failure". Sorry, I'm not allowed to share the file with you...
Thank you - I appreciate you trying to help! I ended splitting the file up into 3 MB segments...not good!
