Grep expression to include carriage return if it's there
Contributor ,
Nov 04, 2016 Nov 04, 2016
Hi all,
Is there a grep expression that is able to handle a break return or other non-text character that might or might not be between a pair of tabs?
I'm using Grep within BBEdit to convert Excel data into tagged XML, to then import into InDesign. However, when someone has put a carriage return within a cell in Excel, my find/replace won't handle that properly. I can use a workaround, but I didn't want to amend the original data if possible.
My expression looks for 7 columns of text, and takes each piece and puts tags around them.
filename    |    full name    |    star    |    company    |    biog    |    city    |    twitter
johnsmith.tif    |    John Smith    |    yes    |    DeLoitte    |    I work at Deloitte and I'm brilliant.    |    New York    |    @myhandle
Find:
^(.*?)\t(.*?)\t(.*?)\t(.*?)\t(.*?)\t(.*?)\t(.*?)$
Replace:
<person>
<picbox href="file://Headshots/\1" />
<name>\2</name>
<star>\3</star>
<company>\4</company>
<biog>\5</biog>
<city>\6</city>
<twitter>\7</twitter>
</person>
But what if one of those columns has a break return but all the others don't? - Just to be clear, it MIGHT have a carriage return, it MIGHT NOT - this is the tricky bit.
Is there a grep expression that can account for that?
If anyone can help, that would be amazing.
Justy
1.3K
Participant ,
If you want to go greo, the closest thing I can think of is
\t?[^\t]+\t?
But you would have to do some extra cleaning.
Otherwise, I would consider scripting given that you can export excel to CSV.
Contributor ,
Ooo that's brilliant.
Would you kindly explain what it's doing? If I repeat it 7 times it picks up all the columns needed if I wrap it in ^ and $.
But I then have a problem with my replace string as I can't work out what bit of the expression is the text and so meant to be kept.
My actual, original find and replace strings so you can see what I'm transforming:
Find
Replace
<bounding>\n<picbox href="file://Headshots/\1" />\n<biogbox>\n<name>\2</name>\n<star>\3</star>\n<company>\4</company>\n         <bio>\5</bio>\n<citybox>\n<city>\6</city>\n<twitter>\7</twitter>\n</citybox>\n</biogbox>\n</bounding>
Many thanks
Contributor ,
Hi again,
Sorry to be a pain, I'm trying to understand your grep expression more. Is my breakdown of it correct?
\t?[^\t]+\t?
\t?      = \t looks for a tab, ? zero or one time
[^\t]+  = [ start of a pattern, ^ beginning of a line, \t tab, ] end of pattern, + pattern appears one or more times
\t?      = (as first line above)
To elaborate on Loic's explanation, just a bit, the ^ inside the opening bracket makes the class "negative" so it finds anything except the characters following it up to the closing bracket.
Participant ,
Trying to morph a xml file from csv via GREP looks very artistic to me. I am not sure I can provide much more help here.
Contributor ,
It's not that scary. It's only plain text either side of the original data. Thanks again.
Participant ,
Some online tools intend to do such transformations.
Give this a try:
CSV To XML Converter - BeautifyTools.com
And let us know.
Contributor ,
I've used a similar website to do the same thing. That's when I decided that should the website ever go down, or it needs to be more complex, I need a way to do it offline. That's where grep is helping. I can certainly get it into a workable format. Having imported over 300 biographies in a few minutes. Just hoping to refine my grep expressions so the original text is tampered with as little as possible.
Any errors are then the client's problem, not mine.
When I get the right expression I'll post back.
Participant ,
Basically it looks for any character other than tab one or more times that can be possibly surrounded by tabs.
So it's
[^\t]+  = any possible character but tab one or more times
