Cant select text in Indesign CC 2017
Nov 04, 2016 Nov 04, 2016
If I attempt to select text in the new Indesign, the program freezes. I've restarted 5x now. How can I enable the updated INDD to select text without freezing?
3.4K
Adobe Employee , Nov 04, 2016 Nov 04, 2016
Hi Amy,
Could you please check the same workflow after unchecked the type Contextual control preference?
Navigate to Preference -> Advance Type -> Type Contextual controls and unchecked it.
Also please email me the document at vinchauh@adobe.com. It will help us in finding the root cause for the issue.
Vineet
Moved out of the Forum Lounge (no technical support is available there) and to the InDesign forum.
Adobe Employee ,
Hi Amy,
Vineet
Participant ,
Nov 29, 2016 Nov 29, 2016
Hi Vineet (and Amy).
I had the exact same problem. Turning off Contextual Controls DID make the problem go away. Then I re-checked the Contextual boxes, and the problem returned, so it's definitely the cause ... or related to it.
Jan 11, 2017 Jan 11, 2017
Hi Vineet,
Problem resolved by disabling Type Contextual Controls (both checkboxes), which is great, but no longer have the CC2017.0 feature I most looked forward to. Look forward to a fix in future update.
Adobe Employee ,
Mar 10, 2017 Mar 10, 2017
Hi All,
A solution for this issue is provided at Troubleshoot text selection issues. Please try the steps mentioned in the link.
Note: You need not to turn off the preferences now with this solution, and should be able to work fine.
Please share your feedback.
Monica Singh
InDesign Team
