Hi Jared
Yes, I believe the file has to be compiled using RoboHelp in
order to make the Glossary Tab work. I'm not sure why or what is
special about it, but as I understand it that's the case. And it's
also the case that each of your end users will not only have to
have the HHActiveX.DLL present, but it has to also be properly
registered with Windows in order for it to work.
I see from your signature line that you are using RoboHelp 7,
so I'm wondering if you have tried the command line compile as
opposed to the other method.
Cheers... Rick
