I have a jsx script that I have been using successfully for 6 months. The script calls indesign and outputs a document.
The first line of the script is #target indesign-11.
Now when I run the script, After Effects starts up and reports that it can't create my document.
This happened a week again, and then somehow remedied itself. Everything was working fine yesterday. Today I have been using Premier Pro for video editing. I then switched back to doing InDesign and my script is back to starting After Effects instead of InDesign.
I'd really like it if #target indesign-11 just started indesign. Any thoughts?
Yes #target is using to starting the application.. may i know where you ran the script? From indesign itself or in Extend script toolkit?
I call the script from python. Here is the command
p1 = subprocess.Popen(['open', '/Users/apple/Documents/Adobe Scripts/IDauto_free1.1.jsx'], stdout=subprocess.PIPE)
This request is handled by extend script.
Simon
Did you upgrade the version? Better use #target indesign instead of #target indesign-11.
No haven't upgraded. I noticed yesterday that if I do not have indesign running then the script will start indesign. But if I do have indesign running the script will start after effects. What kind of madness is this?
