My site was fine, it was uploading properly (to business catalyst) with updates.
After installing Muse 2017, however, everytime I try to update I get this message:
Adobe Muse CC has encountered an error and will now exit. Please report the last few actions you took leading up to this error to the Adobe Muse CC team.
Failed to update the CRCs for some of the included files. Possible reasons: circular references / not all included files were reported correctly / some included files were not exported.
I looked up the problem online and realized it must be an issue with the assets and their names (From this article: Muse: error failed to update the CRCs )
So, I relinked ALL my assets, as well as giving them new COMPLETLY different names.
I'm stuck, I have no clue what is causing this issue?
Participation in the Muse Prerelease Program is under a Non-Disclosure Agreement. All discussion of the beta builds and beta program should be limited to the private http://museprerelease.com forum.
For others reading this thread, the Adobe Muse Prerelease Program is available to all active subscribers who can accept the terms of the Non-Disclosure Agreement. You can join by going to http://museprerelease.com
The prerelease build installs along side the shipping build. The two don't have any over
...Copy link to clipboard
Could you please send us your .muse file to muse-support@adobe.com with a link to this thread or via dropbox , so that we can look into the issue.
Hi
Please download the beta build from below link which fixes this issue.
http://museprerelease.com/discussion/4462/muse-cc-2017-0-1-hotfix#latest
Kratika
The prerelease build installs along side the shipping build. The two don't have any overlap.
Sanjit
I'm a little bit overwhelmed reading forums. I'm having the same issue having this entire site completed www.peakhydronics.com
I've already uploaded the entire website but needed to re-order my layers as the menu was appearing behind the content on some pages. Now when I go to re-load the new files I have the same message pop up. What can I do to fix this and get this site up asap?
Somehow I fixed it by deleting the contact forum widget and then re placing it.
I was having the same issue here, using the Muse 2017 version.
Just by changing the font of the "submit" button on the contact form I solved the problem.
Give it a try.
yup.. change the font worked for some reason... it must be some code that gets executed only on a change in the new 2017 version?
I tried to change the font, but I still cannot export to HTML. Any other solutions?
