Hi All!
I want to export all the images used in our Animate fla project since we need the source files for different applications.
Is there an easy way to do this? I thought I could rename to .zip and try and copy them from the archive but it looks like the structure has changed over the years.
Thanks.
you could use a jsfl script to loop through all items in your library, select bitmaps and then use exporttofile on the bitmaps.
Thanks for your answer.
I've never used a jsfl before. Are there any examples of it?
@kglad thanks
you're welcome.
p.s here's sample jsfl code to export those bitmaps:
var imageFileURL = "file:///C|/exportTest/";
var lib = fl.getDocumentDOM().library;
var item;
for(var i=0;i<lib.items.length;i++){
item = lib.items;
if(item.itemType=='bitmap'){
item.exportToFile(imageFileURL+item.name+'.jpg');
you're welcome.
