force redraw() script
Nov 05, 2016 Nov 05, 2016
Hello such.
You see, I'm doing a script to select a random TextRange in a textframe.
The script works properly (or so it seems) but when the script ends and the TextRange is selected, if I press the delete key (only disappears selection but not selected text)
I tried to use redraw () and app.redraw () at the end of the script but does not seem to do anything.
is a bug??
You know how could I fix it? Thank you very much in advance.
A greeting.
Scripting
1.5K
Adobe
Engaged ,
And if you press the delete key again, then all text frame will be deleted.
Behavior of the TextRange.textSelection so strange. It is not like a manually text range selection.
If it was selected via script, then you can do something with the selected text via script (e.g. delete symbols), but not manually.
Enthusiast ,
Nov 21, 2016 Nov 21, 2016
o-marat 撰写:
Of course is not like selecting text from the UI using Text tool, from UI we can not select individual words without the blank space also been selected.
So that's just how it works, no fix exists.
Nov 06, 2016 Nov 06, 2016
levi23 schrieb:
Hello such.
You see, I'm doing a script to select a random TextRange in a textframe …
Yes I see --> NOTHING
Please show us the code you already have.
Of course
var myDoc = app.activeDocument;
var sel = myDoc.selection[0];
for (a = 0; a < sel.words.length; a++) {
    var W = sel.words;
    W.select(true)
redraw()
I would like the selected text resulting, could be useful for working manually from the program (remove be very useful depending on the code)
Any help please?
Thank you very much
