Hello there,
Keyboard shortcut G for Grid View is working but E for Loupe View is not, or I may be doing something wrong.
I'm using the space bar in the meantime as a workaround.
Well, apparently the problem miraculously has solved itself.
Is there maybe a key that turns these functions on and off so I can avoid this in the future?
I don't see that issue here. Windows 10, Lightroom CC 2015.7.
Have the latest version too. All I get is the error sound when I press E.
What operating system?
Sierra.
I'm not at all familiar with the Mac. Never used one. My only suggestion would be to reset your preferences and see if that makes the difference. Someone else might have a better idea.
I hope so. Thanks for your feedback anyway.
Same goes for Compare View (C), Survey View (N), and People (O). None of them are working.
The only one working is Grid View (G).
If I'm in one of the other views and I press G, I get Grid View. If I'm in e.g., People (O) and press N, I get the error sound and vice versa.
Did you by chance restart your Mac between when it didn't work and when it did?
There is no key combo in LR that would cause this to happen. Has/had to be something in OS X or a problem with your keyboard.
No. I left everything on. Didn't quit LR either.
View was also missing from the menu bar by the way. It's visible again at the same time everything went normal.
