Animate CC - Extensions Issues
Nov 02, 2016 Nov 02, 2016
Hey everybody,  my name is yuval, im an animator.
There are several extensions that i got in CS3 and have to find them for Animate CC in order to start working.
* "New Anim Clip"
* "Replace Library names" (for all the chosen objects in the library together at once)
* "go to frame"  (less important)
is anyone knows where can i find them, or maybe some of them are built in "animate CC" already?
thanks
594
Advocate , Nov 06, 2016 Nov 06, 2016
Can't you just use Find and Replace?
To find and replace symbols, search for a symbol by name. Replace a symbol with another symbol of any type—movie clip, button, or graphic.
  • Select Edit > Find and Replace.
  • Select Symbol from the For pop‑up menu.
  • For Name, select a name from the pop‑up menu.
  • Under Replace With, for Name select a name from the pop‑up menu.
  • To select the next occurrence of the specified symbol on the Stage and edit it in place, select Live Edit.
    Note: Only the next occurrence is selecte
Advocate ,
Found this through a quick Google search: Flash Extensions
If they work in Flash CC I assume they will probably still work in Animate CC.
Hey, thank u for your reply.
I found the monkey site quickly as well, the specific extension I was looking for is not working – "libapend" – replace library names at once.
I thought u will come out with more professional solution.. something that is related to adobe maybe.
I will be thankful if u can help me, i moved to "flash professional 2015" instead of "animate cc" but I still cannot work until I have this extension. Thank you
Advocate ,
    Note: Only the next occurrence is selected for editing, even if you select Find All in the next step.
  • To find a symbol, do one of the following:
    • To find the next occurrence of the specified symbol, click Find Next.
    • To find all occurrences of the specified symbol, click Find All.
  • To replace a symbol, do one of the following:
    • To replace the currently selected occurrence of the specified symbol, click Replace.
    • To replace all occurrences of the specified symbol, click Replace All.
First, I didn’t know about this feature, so thank u for that (I was wondering and asking the support team also if there is an inside feature which replace the extension I was looking for).
let me take a second look on this one, at the first look I'm not sure it solves my problem but I will come back to u on this one..
and while we are on the subject, I'm looking for "goto frame" (not action script and stuff), only picking a number and the scroller of the timeline will jump right to this frame.
And one more thing, as you know- double click on the symbol takes you inside it on the same frame, so what I want is- that I will be able to click on the timeline and by pressing a shortcut, it will take me inside on the same frame I was at. (did I explain it well?)
thank u for your time, its appreciated.
