today I uninstalled my previous AE, Photoshop, Illustrator, Premier Pro & Media Encoder versions, because of an error which occured while starting AE ("Unknown Exception" + something about the AEDynamicLink Plug-In).
I installed the newest version (trial) and here we go with the same error, except the "AEDynamicLink error"
So when I start After Effects CC (Trial version 2017), a window shows up saying: "After Effects Warning: Unknown Exception" whike it initialises the MediaCore. Then I click OK and the same window shows again. After clicking on OK again, it say that there is an unexpcted error while starting the application.
Media Encoder also crashes, but without any errors. It just freezes while starting. (same problem with the older version before uninstalling).
Character Animator CC crashes after starting with no error.
I've searched the last few hours but haven't found the solution yet.
Hopefully someone can help me,
thanks !
Thanks for your help Roei Tzoref.
It seems like I've found the problem.
I've searched for another problem which appeared when I've started installer (like the Adobe Creative Cloud Installer). It always said: "Windows Smart Screen can't be reached" (example picture). That's no real problem but I wondered how this can happen, because I've activated it everywhere where its possible.
I found this entry via google.
In this thread somebody says:
[..] your TCP/IP or Winsock stack could be borked and will ne
...Copy link to clipboard
what firewall or antivirus have you got installed? (AVG is notorious for causing problems with launching Ae) I would check those. try to disable and see if this is the cause and then fix it. reading this would probably be helpful: After Effects or Premiere Pro crashes after starting
[..] your TCP/IP or Winsock stack could be borked and will need to be rebuilt.
Open a command prompt as Administrator.
netsh i ip r all
and press enter.netsh winsock reset
and press enter.I have no idea why it was broken (or what it is) but I did what he said and now everything works fine!
It fixed the SmartScreen "problem" and also my AE/Character Animator/Media Encoder/Premier Pro error
Is there a Mac solution??
Hello, did you fine the solution for mac? if yes, can you please help me, i have a finalin three days and i'm behind at work:(
I need one solution for Mac as well...
Same here
same issue here, on mac...
Same here on Mac ... -_-
