I'm developing a script. I would like to manage dimensions in millimeters; so I added at the top of the script:
app.scriptPreferences.measurementUnit = MeasurementUnits.MILLIMETERS;
But then I try to resize the page, and the dimensions are managed as points:
app.activeWindow.activePage.resize(CoordinateSpaces.INNER_COORDINATES, AnchorPoint.CENTER_ANCHOR, ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH, [240, 100]);
Can you help me to understand where I'm wrong?
Gregorio
Hi Gregorio,
it is not working in any environment.
all x and y values for resize() are accepted as points only.
The same with reframe() and transform().
Recommended:
Indiscripts :: Coordinate Spaces & Transformations in InDesign — Chap.1-3
Indiscripts :: Coordinate Spaces & Transformations in InDesign — Chap.4 (Draft)
There is UnitValue you could use to do the necessary conversions.
var convertedValue = UnitValue(100,MeasurementUnits.MILLIMETERS).as(MeasurementUnits.POINTS);
Uwe
Personally, about MeasurementsUnits:
// ----------- Script beginning -----------
var myDoc = app.activeDocument;
var savedHorizontalMeasurementUnits = myDoc.viewPreferences.horizontalMeasurementUnits;
var savedVerticalMeasurementUnits = myDoc.viewPreferences.verticalMeasurementUnits;
myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
// ----------- Script end -----------
myDoc.viewPreferences.horizontalMeasurementUnits = savedHorizontalMeasurementUnits;
myDoc.viewPreferences.verticalMeasurementUnits = savedVerticalMeasurementUnits;
It doesn't work in my environment... Can't understand!
Gregorio
Hi Gregorio,
Recommended:
Uwe
Hi Uwe,
Right!
var W = UnitValue("240mm").as('pt'); ;
var L = UnitValue("100mm").as('pt');
app.activeWindow.activePage.resize(CoordinateSpaces.INNER_COORDINATES, AnchorPoint.CENTER_ANCHOR, ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH, [W,L]);
Hi Obi-wan,
in this case changing the viewPreferences is not necessary.
resize
[W,L]
Uwe
You're right!
Just a habit of systematical work in a "millimeters" context!
