Hello, I have troubles when I import files from my Sony A7RII. Lightroom reduces the size of my RAW files. He imports files 5168/3448 pixels, although they should be twice this size. On the memory card the files are ok. When I use a Sony A900 ( 24,4 MP) everything works fine.
Does anyone knows where it comes from
Thank you
I don't have that camera. I'm still using a 24 megapixel small sensor camera. I looked up the specifications for your model, and it would appear that your camera is set to take a "medium" sized full frame image or a large APS -C image. Here is a screenshot from the online specs:
The Lightroom import process doesn't do anything to your images. In fact, you cannot change the size of an image in Lightroom. It seems that you need to double check the image size settings in your camera setup menu.
I just have seen that I have the same problem whith the camera raw from phtoshop (LRCC 2015, photoshopCC 2017)
Thank you for your answer. You are right my camera was set on aps size when I used it to make a video and I didn't realize that the video settings werre still on. Thank you
