Hi
I have created a talking head. It's all in a graphic symbol.
I want it to move from side to side as it talks, but when i create classic tween the head just goes up in the "air" above the shoulders. Why is that!? What am i doing wrong??
(I know the basics of tweening, but i have no idea why this doesn't work)
you probably messed with "the white point" between two frames. I mean the pivot point of transformation. When it changes between keyframes, objects jump around randomly. Delete the later keyframe and put it again without changing the pivot point.
use motion tween if you want better control of the tweened object's path.
I figured that out, but thanks anyway!! ❤️
