Hi Everyone,
after today's updating PS to the CC.2017 I can't open images from Ligtroom into the PS.2017 as layers. Have someone the same problem?
After a few seconds Ligtroom show error that the files can not be opened because PS CC 2017 can not be run.
I've checked the bookmark "external edithing" in ligtroom and there is ok, I see "edit in adobe photoshop cc 2017"
Thank you for your answer,
Pavel
It the workarounds described in the linked bug report above don't help (including starting PS manually), you can roll back to LR CC 2015.6.1: Lightroom roll back to prior update version
Start Photoshop before invoking the Edit In command -- that works for most people. Also, please add your me-too vote to this bug report in the official Adobe feedback forum, making it a littlle more likely Adobe might prioritize a fix: Lightroom 6.7: Opening photos in Photoshop from Lightroom using Edit In does not work correctly for ... That bug report also contains another workaround.
I'm sorry, but the process doesn't work in win10 64 bit and latest versions PS and LR...
