Trying to synchronize audio but the increments on the timeline are too wide. So dragging a wav file left or right moves it too far. I've turned off snap but it still does it. How do I remove frame by frame incremental time? I need smoother dragging because getting two wav files to play on top of each other is impossible and I have echo. I've zoomed in as far as I can go. I can move the mouse where I want but when I click the timeline it snaps forward or backwards to what looks like a 10th of a second. I need 100th of a second.
Just to reiterate: it looks like 29.97 frames per second is my limitation. I have version 12.
Can i switch the time increments to miliseconds on version 12 of Premier Elements?
The lowest you can go is 1/29 per second depending on the framerate of the project (alt+arrow left/right)
If you want more control over audio you need a more professional program like Premiere Pro.
Or try Audacity to sync.
There is a good tutorial about how to use the free Audacity to sync audio for Premier Elements.
