How to proof (PDF proof ) only certain layers of a design.
Means, layer should be visible in the application , when we go for PDF proof hide the layer with inDesign capabilites.
please suggest me ideas on it.
Make them non printing layers. Right-click on the layer in the Layers panel and select Layer Options for [Layer]. Turn Printing off.
Thanks for the reply , let me try this and share you if i have difficulty
will it be useful , even we generate PDF proof using third party libraries on the design xml
When it's time to print a proof of the layer(s) you want to be visible but not print, double-click on each layer. Choose Show Layer but uncheck Print Layer.
When you export the PDF, in the Export PDF dialog on the General panel, choose Export Layers: Visible & Printable.
Let me try this . Thanks for the reply
