That is the message I get when I click upload to you tube using PE9. Has been for over a week now.
YouTube has changed some settings and it's causing havoc for all direct-to-YouTube interfaces.
The best bet is output your video from the program in a web-based format and then upload it to YouTube using the upload interface on their web site.
Unfortunately, version 9 pre-dates the AVCHD output setting, which is the ideal format for uploading to YouTube. Your best bet may be a WMV file.
Do you know if PE15 has the same problem? Direct upload is important. thank you
It appears YouTube has shut all versions down at this point.
Facebook and Vimeo uploads are working fine though, so it's definitely YouTube that's the fly in this ointment.
how do you do that?
Go to Share/PC and select the Windows Media option. From the Preset menu, select HD 720p. This will output a WMV file, when you can then upload to YouTube on their web site.
