Hi i need help with making a book layout in In design or Illustrator. I want it to look something simple like this book. However im only using a single sheet paper(17x11), so when I print the layout I can fold the sheet to make a book like this. The book is 17x11 and has 16 pages.
This is a job for InDesign, even if some of the art in done in Illustrator.
A book like this should be set up as facing pages, using an 8.5 x 11 page size. That is how professional printers will want it set up, and that is also how you should set it up for home printing. -- (Did you mean 16 8.5 x 11 pages, or 16 11 x 17 pages?)
No I mean I have to use one sheet of paper for the book. The paper can be either 11x17 or 8.5x11 landscape or portrait. I need help setting up the guidelines because when I print the sheet I'm gonna fold it into a book. My book has 16 pages so I need to divide the document paper into 16 even parts. I'm having trouble on that part.
Presumably 8 pages sheet work (8 pages printed each side of the 11" x 17" sheet).
You do not want to design your actual document this way.
Make a PDF as usual, and process this instead.
