I've just downloaded the latest version of XD, went to try the tutorial, nothing, blank screen.
i can't draw artboards, just get a grey pasteboard. same when trying UI kits or templates.
have un/re-installed three times now.
any ideas?
One last suggestion would be to boot your device into Safe Mode (hold shift key at boot til you see the progress meter after the apple logo), if you've booted successfully to safe mode the upper right says SAFE BOOT.
See if XD runs in that mode (on retina it will run slow and be incorrectly scaled in safe mode as it's using a stock driver, but you should at least see artboards)..if it works in this state, then perhaps the issue is simply something conflicting with Open GL like a startup item or a
...Copy link to clipboard
Hi Scott,
This is the first we've seen of this particular issue, it looks like the design surface isn't rendering at all.
Had previous versions been working for you?
Can you post your OS version, and stats on your Graphics card? Basically a screenshot of 'About this Mac' would suffice and the first page of the Hardware Overview of the System Report if possible?
Thanks in advance.
Best,
Corey L,
Adobe Systems, Inc.
Hi Corey;
weird isn't it...previous version worked fine to my knowledge, haven't really had to use XD properly yet, but thought i'd give it a go tonight and do the tutorial, and found this problem. here's a screenshot of my spec.
out of interest, i booted up new photoshop and am having a similar issue, can't use dartboards....
oh and i'm on el capitan 10.11.6
Can you paste the output of the 'Graphics/Displays' portion of the System Report? If Photoshop is also having issues, then I feel there may be something up with your Open GL driver or graphics hardware.
ok....this isn't sounding good.
All very useful but nothing jumps out. If other apps are misbehaving and something is wrong with your graphics subsystem then there is not much I can advise at the moment.
If you have spare cycles, it's possible that there's relevant information in your Mac log that could help us diagnose this.
Here you go:
07/11/2016 20:09:53.918 Adobe XD[1211]: SpWelcomeScreenWindowController::windowDidLoad 376.871002ms
07/11/2016 20:09:53.962 Adobe XD[1211]: [Crashlytics] Version 3.7.0 (102)
07/11/2016 20:09:54.399 Adobe XD[1211]: SpWelcomeScreenWindowController::didFinishLoadForFrame 857.711975ms
07/11/2016 20:13:15.769 Adobe XD[1211]: Unable to acquire GL context. Error code: 0
07/11/2016 20:13:16.354 Adobe XD[1211]: SpWindowController::windowDidLoad (load file) 574.059021ms
07/11/2016 20:13:44.971 Adobe XD[1211]: Unable to acquire GL context. Error code: 0
07/11/2016 20:13:45.634 Adobe XD[1211]: SpWindowController::windowDidLoad (load file) 661.958984ms
07/11/2016 20:13:59.062 Adobe XD[1211]: Unable to acquire GL context. Error code: 0
07/11/2016 20:14:21.942 Adobe XD[1211]: Unable to acquire GL context. Error code: 0
07/11/2016 20:14:22.253 Adobe XD[1211]: SpWindowController::windowDidLoad (load file) 309.126007ms
07/11/2016 20:15:37.961 Adobe XD[1211]: Unable to acquire GL context. Error code: 0
07/11/2016 20:15:38.641 Adobe XD[1211]: SpWindowController::windowDidLoad (load file) 678.049988ms
07/11/2016 20:16:14.341 Adobe XD[1211]: Unable to acquire GL context. Error code: 0
07/11/2016 20:16:14.660 Adobe XD[1211]: SpWindowController::windowDidLoad (load file) 317.520996ms
07/11/2016 20:19:08.993 Adobe XD[1237]: SpWelcomeScreenWindowController::windowDidLoad 251.128006ms
07/11/2016 20:19:09.027 Adobe XD[1237]: [Crashlytics] Version 3.7.0 (102)
07/11/2016 20:19:09.470 Adobe XD[1237]: SpWelcomeScreenWindowController::didFinishLoadForFrame 728.593994ms
07/11/2016 20:19:11.232 Adobe XD[1237]: [Crashlytics:Crash] WARNING: the user prompt feature is enabled. As of Crashlytics 3.0.0, implementing a user prompt is the application's responsibility. See Crashlytics.h's notes about -crashlyticsDidDetectReportForLastExecution:completionHandler:
07/11/2016 20:19:13.339 Adobe XD[1237]: Unable to acquire GL context. Error code: 0
07/11/2016 20:19:13.744 Adobe XD[1237]: SpWindowController::windowDidLoad (load file) 392.915985ms
07/11/2016 20:22:27.028 Adobe XD[1237]: Unable to acquire GL context. Error code: 0
07/11/2016 20:22:27.784 Adobe XD[1237]: SpWindowController::windowDidLoad (load file) 755.104980ms
07/11/2016 20:51:04.806 Adobe XD[1290]: SpWelcomeScreenWindowController::windowDidLoad 369.815002ms
07/11/2016 20:51:04.859 Adobe XD[1290]: [Crashlytics] Version 3.7.0 (102)
07/11/2016 20:51:05.502 Adobe XD[1290]: SpWelcomeScreenWindowController::didFinishLoadForFrame 1065.489990ms
07/11/2016 20:51:07.063 Adobe XD[1290]: [Crashlytics:Crash] WARNING: the user prompt feature is enabled. As of Crashlytics 3.0.0, implementing a user prompt is the application's responsibility. See Crashlytics.h's notes about -crashlyticsDidDetectReportForLastExecution:completionHandler:
07/11/2016 20:51:07.699 Adobe XD[1290]: Unable to acquire GL context. Error code: 0
07/11/2016 20:51:08.255 Adobe XD[1290]: SpWindowController::windowDidLoad (load file) 543.203003ms
07/11/2016 21:25:56.385 Adobe XD[1290]: Unable to acquire GL context. Error code: 0
07/11/2016 21:25:56.698 Adobe XD[1290]: SpWindowController::windowDidLoad (load file) 311.309998ms
07/11/2016 21:48:14.522 Adobe XD[1290]: BUG in libdispatch client: kevent[EVFILT_MEMORYSTATUS] add: "Operation not supported" - 0x2d
07/11/2016 21:48:14.632 Adobe XD[1290]: assertion failed: 15G31: libxpc.dylib + 78286 [54D1328E-054E-3DAA-89E2-375722F9D18F]: 0x89
07/11/2016 22:00:49.357 Adobe XD[1290]: Unable to acquire GL context. Error code: 0
07/11/2016 22:00:49.792 Adobe XD[1290]: SpWindowController::windowDidLoad (load file) 433.152008ms
07/11/2016 22:07:31.971 ReportCrash[1999]: Saved crash report for Adobe XD[1290] version 0.6.2.7 (0.6.2.7) to /Users/scottmarlow/Library/Logs/DiagnosticReports/Adobe XD_2016-11-07-220731_Scotts-MacBook-Pro.crash
07/11/2016 22:07:36.561 Adobe XD[2002]: SpWelcomeScreenWindowController::windowDidLoad 284.734009ms
07/11/2016 22:07:36.617 Adobe XD[2002]: [Crashlytics] Version 3.7.0 (102)
07/11/2016 22:07:37.313 Adobe XD[2002]: SpWelcomeScreenWindowController::didFinishLoadForFrame 1036.687988ms
07/11/2016 22:15:44.953 Adobe XD[2002]: [Crashlytics:Crash] WARNING: the user prompt feature is enabled. As of Crashlytics 3.0.0, implementing a user prompt is the application's responsibility. See Crashlytics.h's notes about -crashlyticsDidDetectReportForLastExecution:completionHandler:
07/11/2016 22:15:45.906 Adobe XD[2002]: Unable to acquire GL context. Error code: 0
07/11/2016 22:15:46.440 Adobe XD[2002]: SpWindowController::windowDidLoad (load file) 523.088989ms
07/11/2016 22:39:20.399 Adobe XD[2002]: Unable to acquire GL context. Error code: 0
07/11/2016 22:39:21.278 Adobe XD[2002]: SpWindowController::windowDidLoad (load file) 877.041992ms
At this point we can confirm that something is definitely wrong with OpenGL on your system, but beyond that I can't speculate if it's hardware or a driver issue. Apple doesn't make it easy to simply refresh/update your graphics drivers independently of a wholesale OS update.
I'm not about to ask you to upgrade to Sierra but perhaps it would to the trick. Beyond that I personally am out of ideas but will continue to search around and will report back if I find something.
See if XD runs in that mode (on retina it will run slow and be incorrectly scaled in safe mode as it's using a stock driver, but you should at least see artboards)..if it works in this state, then perhaps the issue is simply something conflicting with Open GL like a startup item or application that is running in your menu bar, etc. Restarting in non-safe mode would return to using the stock Intel Iris 5100 drivers which may or may not be corrupt so if it goes back to not working you may be just out of luck.
Hi Corey;
Well, what do ya know.......
i booted in safe mode, XD worked FINE....Photoshop not so much......I booted in admin account both XD and Photoshop absolutely fine, then.....
booted back up in my normal user account, both XD and Photoshop absolutely fine and dandy.
Such weirdness. I still think my Mac has a few issues, with restarting etc, so maybe time for a good old back and and restore to latest OS. Many thanks for your time and help on this.
Take Care
Scott
One more for good measure..if you happen to use Chrome it would be interesting to know how it's fairing with Open GL on your machine. You can type chrome://gpu/ in the URL bar and see something like this at the top:
Graphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Hardware accelerated
Rasterization: Hardware accelerated
Video Decode: Hardware accelerated
Video Encode: Hardware accelerated
VPx Video Decode: Hardware accelerated
WebGL: Hardware accelerated
Ok, good morning Corey, (and Peter) thanks for your time on this, it certainly is frustrating. I'll pick this up after work this evening.
Sent from my iPhone
Data exported | 11/8/2016, 9:13:05 PM |
Chrome version | Chrome/54.0.2840.71 |
Operating system | Mac OS X 10.11.6 |
Software rendering list version | 11.12 |
Driver bug list version | 9.00 |
ANGLE commit id | 905fbdea9ef0 |
2D graphics backend | Skia/54 a21f10dd8b19c6cb47d07d94d0a0525c16461969 |
Command Line Args | Chrome.app/Contents/MacOS/Google Chrome --no-startup-window --flag-switches-begin --flag-switches-end |
Initialization time | 96 |
In-process GPU | false |
Sandboxed | true |
GPU0 | VENDOR = 0x8086, DEVICE= 0x0a2e *ACTIVE* |
Optimus | false |
AMD switchable | false |
Driver vendor | |
Driver version | |
Driver date | |
Pixel shader version | |
Vertex shader version | |
Max. MSAA samples | |
Machine model name | MacBookPro |
Machine model version | 11.1 |
GL_VENDOR | |
GL_RENDERER | |
GL_VERSION | |
GL_EXTENSIONS | |
Disabled Extensions | |
Window system binding vendor | |
Window system binding version | |
Window system binding extensions | |
Direct rendering | Yes |
Reset notification strategy | 0x0000 |
GPU process crash count | 0 |
Tile Update Mode | Zero-copy |
Partial Raster | Enabled |
ATC | Software only |
ATCIA | Software only |
DXT1 | Software only |
DXT5 | Software only |
ETC1 | Software only |
R_8 | GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT |
BGR_565 | Software only |
RGBA_4444 | Software only |
RGBX_8888 | Software only |
RGBA_8888 | GPU_READ, SCANOUT |
BGRX_8888 | GPU_READ, SCANOUT |
BGRA_8888 | GPU_READ, SCANOUT, GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT |
YVU_420 | Software only |
YUV_420_BIPLANAR | GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT |
UYVY_422 | GPU_READ_CPU_READ_WRITE, GPU_READ_CPU_READ_WRITE_PERSISTENT |
I have to turn in now, but will pick up this conversation tomorrow, thanks Corey.
One other quick sanity check, after loading a file can you hit cmd-0 to zoom to the contents of the document? If the canvas is still empty, it's looking like an odd graphics driver issue.
no, CMD-0 doesn't work, nothing changes...
