Hi All,
Is it possible to write the content in particular column like 4 or 6 etc..?
I have column count with the Heading.
Before script:
After Script, (array content placing in 5 column
Simple code for your reference:
var myArray = ["PASS", "FAIL", "PASS"]
alert("myArray: " + myArray)
var myJoin =myArray.join("\n");
alert(myJoin)
var csvFile=File(Folder.desktop + "/somefile.csv");
csvFile.open('w');
csvFile.write(myJoin)
csvFile.close();
Thanks in Advance
Siraj
1. if you read a .csv file and split text by "\n" ==> you have an array (each CSV line is an element of this array)
2. Assuming you have another array with data to input ==> alike ['FAIL','PASS','FAIL']
3. Assuming you want to input this as a 5th column
so you need to loop - split - splice - join
something like:
var
mTotalArray, // csvFile.read().split("\n")
mLineArray, // current mTotalArray element.split(",")
mInputArray, // your data
k,
m
...Copy link to clipboard
Open your.csv file in Notebook to see its real structure. You need to modify this 'text' body using this structure (row after row with 'comma separated' elements.
Jarek
Thank you Jump_Over for your quick response...
Is it possible to placing the content by (i.e.,) Column count 5 or 10 or whatever as per job input.. (not by "," comma seperator)
1. Earlier stage itself, read the heading column count like "Missing Font", "Missing Link" etc... from Input.csv
See below code finding the Column count (its your code only, got from forum)
//----------------------Pick Missing Font Column Count----------------------------
MissingFont_xIdx = (cLine).search("," + String(Missing_Font_Heading));
if(MissingFont_xIdx == -1)
alert("Missing Font Heading is not in Standard Format. Please check and Fix")
exit(0)
Missing_Font_column = cLine.slice(0, MissingFont_xIdx).split(",").length - 1;
alert("Missing_Font_column: " + Missing_Font_column)
//----------------------Pick Text Size Column Count----------------------------
2. Grab the value in myMissingFont_Array (refer top of the thread or Previous link created on yesterday)
3. Finally write it in Input.csv Column (as per Heading Column) (this is my request now)
Regards
Siraj
something like:
var
k,
mTargetColumn = 5; // number of target column
for (k = 0; k < mTotalArray.length; k++) {
mLineArray = mTotalArray
mLineArray.splice(mTargetColumn - 1, 1, mInputArray
mTotalArray
//After this you can write entire string - mTotalArray.join("\n") - into your CSV file
Jarek
var f = File.openDialog();
f.open('r');
var arr = [];
while ( !f.eof ) {
arr.push ( f.readln() );
f.close();
arr[0] = arr[0]+"\t\t"+"result";
arr[1] = arr[1]+"\t\t"+"FAIL";
arr[2] = arr[2]+"\t\t"+"SUCCESS";
arr[3] = arr[3]+"\t\t"+"FAIL";
f.open('w');
f.write(arr.join("\r"));
f.close();
