My After effects sequence is smaller in premiere pro through the dynamic link. Not sure what is causing this but before i updated to the 2017 version it never did this. I also was working a lot in AE yesterday so its possible i changed a setting somewhere. Please help!
This is an issue we're hoping to have fixed soon, but you don't need to revert to an older version: there's an easy workaround. Dynamic Link is taking the comp resolution setting from AE, so all you need to do is set the resolution to "Full" in the Composition panel or comp settings in After Effects.
Go back to using a previous version until Adobe issues the SECOND bug fix for this new version. Typically, the first bug fix addresses common problems, but ends up breaking features that were working just fine previously. The second bug fix is for the things the first bug fix broke.
By then you should have a mostly-functioning new version.
how do i revert versions?
Sorry, I don't have the link & instructions to download & install previous versions. But someone will. Sit tight.
Hello - this isn't an easy workaround for those of us with many comps linked to a premiere project. Do you have a timeline when this will be fixed? It is costing a lot of time. Thank you.
