Hi everyone!
The problem is - when I change keyboard layout from English into Russian or vice versa After Effects stops responding and hangs indefinitely.
Could you help, what should I do in this situation?
Nobody can tell you anything without proper system info or other technical details like exact version of Ae.
Mylenium
Version of AE is actual (CC 17). The problem existed also in an earlier version.
My PK specs:
intel core i5-4460
nvidia gtx 960
16 GB memory
I think the problem is not in my PK spec.
In Photoshop or other Adobe program everything's ok when I change my keyboard language, but in After Effects .... the program just doesn't respond and hangs.
Is there anyone who can help???
try to reset your preferences: Reset After Effects Preferences
other than that I would suggest you contact support directly: Contact Customer Care
I had a similar problem, but after running ctfmon.exe the problem was solved. ctfmon.exe can be added to startup if it was previously disabled.
