Hi!
I changed the name of one of my catalogs (3 in total. Don't ask me why). And now when backing up just this renamed catalog LR does not compress the
lrcat -file anymore to Zip-file.
All other (unrenamed) catalogs are compressed in backup process.
Can someone tell me what could cause this? Seems that everything else works like before.
Windows 10 64bit, LRcc latest update.
If it does not zip it, how does it store the backup then?
It just stores the uncompressed lrcat -file as it used to do in former LR-versions.
Just to make sure ... you definitely opened LR CC2015 and not accidentally some LR5 that is still on the drive?
Do you backup to the local disk?
What is the size of the catalog?
I have not tested and confirmed this, but it may be that case when backing up to any other disk than the local and/or when the catalog has a certain size.
I'm not at my LR computer currently so I can not test and confirm.
Yes I'm in LR 2015cc. I backup to local drive. This is my biggest catalog containing about 170000 pictures and the size of lrcat -file
is 3,72 Gb (uncompssed).
The other tree catalogs are much smaller. These are still comressed to zip when backing up. So this is quite mysterious.
I don't like the idea to remove and reload LR, but may be I have to. On the other hand if everything works why bother. The only
downside is the big size of the file.
Let me check that ... I'll get back to you here ... will take some time though.
OK, I got some information for you.
There is a limit for (original ZIP) compressing files which is 4GB - this also applies to the zipper used within LR. While there are ZIP-tools that are able to compress files larger than 4GB, the zipper used in LR is limited to exactly these 4GB.
You 3.72GB catalog probably does not zip due to some margins of error.
That said, what you see is (unfortunately) normal behavior in LR.
IMHO, since Lr6 can only be used on 64Bit systems, I feel that the zip technology within LR should be updated to later version which supports files larger than 4GB (i.e. ZIP64) - I'll forward this as a feature request.
Many thanks for your help.
Its interesting to know about that limitation. I "solved" the problem by returnin to the last unrenamed lrcat -file I had, and now
it works just like before: catalog is compressed to Zip although the size is the same 3,72Gb. So I think something went wrong in
renaming.
But it would be fine if that 4Gb limit goes away in future, since the catalogs are growing as years are passing and LR gets new
features.
Adobe wants to have 'feature paritiy' between Mac and Windows versions of LR. While ZIP64 is fully supported for Windows it is not fully supported on Mac - Zip (file format) - Wikipedia .
