delete %20 space character
Nov 10, 2016 Nov 10, 2016
Hello,
I've written a script which gives the user a list of links in the active document and returns the selected links in an array. It then searches a folder full of packaged INDD files and searches the links folders.
What I want to do is write an if statement that matches the two names.
However, the result of searching the folders puts %20 instead of a space so they never match.
How would I delete the %20 or add a %20 where there is a space character so that they match?
Scripting
567
Guide , Nov 10, 2016 Nov 10, 2016
use decodeURI
Guide ,
use decodeURI
Guide ,
Guide ,
For example..
var myFolder = File.openDialog("Select the Folder");
mydoc=app.documents[0];
if(myFolder!=null){FilePath=decodeURI(myFolder);}
alert(FilePath)
myFiles = myFolder.getFiles();  //store the target files in a variable
for ( var i = 0; i < myFiles.length; i++ ) {
if (myFiles instanceof Folder ){
    var myFileLinks = myFiles.getFiles("Links");
    for ( var l = 0; l < myFileLinks.length; l++ ) {
    var linkChecker = myFileLinks.getFiles();
    for ( var o = 0; o < linkChecker.length; o++ ) {
        for ( s = 0; s < mSelected.length; s++ ) {
            if (linkChecker.decodeURI() === mSelected.name) {
                $.writeln("found it");
                        }else ("Didn't work")
This is what I have, the decodeURI doesn't seem to work where I have put it.
linkChecker.constructor.name returns file so it should work?
Guide ,
Please give the code you used for myFolder... in your first line you called (myFiles = myFolder.getFiles();  //store the target files in a variable)
It's OK I got it working, I wasn't using it properly.
decodeURI(uri string)
I was using this as a property and not a function
