Quick Reset Required!
Guest
Nov 10, 2016 Nov 10, 2016
While I'm learning Ch, I'm constantly making a adjustments to what effect it has, but the problem with this is, I soon forget where I was in the first place?
1. The Undo cmd+Z and Redo shift+cmd+Z is very useful, but sometimes I would just like to be able to Reset and start again! Is there a Reset option?
2. I would like to turn off the options/settings, so I can see, from scratch, what each does in turn. Is there a Blank Canvas of Settings? Hope that makes sense!?
2.0K
Guest
I notice that when I click on the Scene... I can make adjustments and I get a X... If I click on this, it resets to default setting. Great!
However, when I click Puppet, I seem to get the same settings, but when I make adjustments.. no X? You have to double click and then enter 0, press Return/Enter to reset?
Adobe Employee ,
1. Best option for a reset is in the history window. Window > History. Just highlight the first thing in the list and you'll rewind to the start.
2. In the puppet panel some properties (track item behaviors) have a little menu icon next to them - you can remove or hide them in the scene from there.
3. The puppet values are a foundation, the defaults for your puppet. Yes, there is no X - you determine the defaults for what works best with your art. Once you're in a scene, that X means "restore to default" - whatever you've set originally in the puppet panel.
Guest
Hi Again!
The History Panel.... In Ps I paint and use History a lot.. never gave this a though in Ch... amazing!
I've just checked this out... Selected it from Windows.... Wow.. it goes way back to when I first started using and not just the latest session! I've pulled the History Panel away from the Main WorkSpace and have it as a floating Window.. this will be very useful!
I'm still not 100% sure why there are two Properties.. Panels that seem to be showing the same thing, although one is slightly different. However, it may become a bit clearer when I get further into Ch!? I'm still working on a head and one eye! Slow... I know!
Thanks again for your invaluable help!
Guest
Just realized  the Floating History Panel remains a part of the WorkSpace I created... So it pops back up as soon as I open Cn... Excellent!
Contributor ,
Apr 12, 2023 Apr 12, 2023
I have created about 15 different tracks in a scene by adding a lot of assets. I need to be able to reset ONLY the puppet, and not get rid of all of the other assets that are perfectly timed in the scene.
Is there a way to do that?
