It's actually the whthost.js file that needs to be edited, as
described in
Rick
Stone's Skinny on Skins tutorial,, available for free at his
site. Look for the TOC > Using additional page images in the TOC
topic. (The title value is what you'll be changing.)
Hints:
* Use "\n" (without the quotes) for line breaks when needed.
* Don't add spaces or line breaks as you type inside this
area: let RH control where indents and line breaks will occur.
* Save the edited file somewhere and use it to overwrite the
new file that RH will create each time you generate.
This only works for pages, not for books. See an example from
my usage (both an alternate image and descriptive text) in the
attached code.
Good luck,
Leon
