I am having an issue with InDesign that is plaguing many of my documents.
Issue:
Attempted solutions:
I have attempted the below solutions but they have not helped
I anyone has as any resolution or helpful advice please let me know!
Harbs. any suggestions?
Thank you!
Shmuel
If possible can you please mail me your document so that we can look into the tabs issue that you are facing?
Also as a workaround you can try the following:
Navigate to Preference->Advance Type -> Type Contextual Controls and disable the first preference “show for Character Alternates, Fractions, Ordinals and Ligatures”
Let me know if this helps
Thanks and regards,
Aman
[personal email removed as per forum guidelines]
[Corrupt documents can be sent to idfile@adobe.com as directed here
...Copy link to clipboard
Thanks and regards,
Aman
[Corrupt documents can be sent to idfile@adobe.com as directed here:
https://helpx.adobe.com/indesign/kb/troubleshoot-file-issues.html ]
InDesign Engineering Team
Aman,
I have followed your suggestion and that workaround has resolved the issue.
I have emailed you the file so we can get a full resolution to this issue.
Shmuel
I tried this workaround, and it worked once, then reverted to the locked Type tool. This is extremely frustrating. Sometimes, I can restart the program, or restart the program to use the other tools, but the tools lock up once I select the type tool
I have a similar program. I'm working on a rather large document. When trying to make changes to the footnotes, or change type the app simply freezes. I've tried all sorts of things and it keeps freezing!
Hi, I'm experiencing the same problem! The app freezes when I select text or use the paragraph styles pane in any capacity. I've attempted the above solutions and have tried other workarounds, but nothing has helped. Is there anything else I can try? I am on a Macbook Pro (Monterey) using Indesign 17.4 (but have also tried with older versions as well, and it persists).
Thanks in advance!
Hannah
I'm currently in the same boat. Infuriating.
This is craziness!! I uninstalled and installed InDesign again andthe isue of freezing text continues. I have 2020 and this seems to be an issue since 2016? I am about to pull my hair off working on a presentation!! HELP!
Hi CDS-37
In addition to uninstalling and reinstalling, did you also try the suggestion from Aman earlier in this thread?
Navigate to Preferences > Advanced Type > Type Contextual Controls
Jane
Hi @jane-e: I'm having the same issue with a document. Every time I open the document/select a text box/highlight text, really anything, the document freezes. I tried turning off the preference you've mentioned in Advanced Type. Any other suggestions to resolve this issue? It's been ongoing with the last few creative cloud updates. Thanks!
