installed cc17 yesterday, all good until just now, opening an ae15.3 project i get the error below.
Definitely try reloading the footage to see if that fixes the problem. This could have happened if you moved the footage to a different folder.
i did try a reload the footage, then cc17 crashed. all source files in their correct folders and haven't been moved. have to export for delivery, going back to 15.3. will troubleshoot this weekend
Why don't you just wait for the second bug fix to come out?
The FIRST bug fix typically fixes common bugs -- and who knows, yours may be among them -- but breaks things that once worked just fine.
The SECOND bug fix generally fixes the bugs created by the first bug fix.
In addition you can probably look forward to a third bug fix, which addresses more exotic & rare bugs.
What to do in the meantime? Use an earlier version.
More unhelpful comments from Mr LaRonde. If no-one used new versions of software then these bugs would take 10 times longer to be routed out as it would just be left to the dev team to find them.
How did the troubleshooting go?
If the answer is, "not well", I have some follow-up questions.
i restored my startup drive from an image just before i installed cc17, i ran the updates and installed again last weekend, and that problem seems to have evaporated. have had a few other odd issues, for example in one of my projects converted from 15.3, deleting a nested comp in a particular comp will cause ae to crash
Glad it's working for the most part! That crashing is an odd thing for it to do. Now I'm really curious. What effects, expressions, etc. are in it?
Let me know how that works for you! In the past, when some new versions come out I've had to start a new project with the new version. If there are other ways to avoid this, I'd love to know.
