I'm having a heck of a time getting RH 7 to work correctly.
When I try to open a project that was created in RH5, I get an
error that says:
quote:
Runtime Error!
Program: C:...
This application has requested it to terminate in an unusual
way.
Please contact the application support team for more
information.
Then the program crashes.
If I then try to open the project again, I get a message that
reads "The parameter is incorrect." and then RH crashes.
Basic computer info:
*XP
*Plenty of memory
*Have administrator rights
*RH5 ran with no problems
*Working in RH HTML
*RoboSource no installed
*Group, not individual license
*Using Dreamweaver to create HTML files to import
*Others in my office haven't had any problems opening much
more complex RH5-created projects in RH7
Things I have tried but have failed:
*Update RH: same errors as original
*Uninstall, reinstall, update: same errors as original
*Rename .CPD and reopen: same errors as original
*Rename .CPD & .XPJ and reopen with .HHP: opened in RH5,
saved, closed, crashed as it closed
*Open using different administrative user: same errors as
original
*Create new project, import newly-created HTML files,
generate help, save, close, reopen: same errors as original
*Open sample project, import HTML files, generate help, save,
close, reopen: get "parameter is incorrect" error, but opens
project
*Open sample project, create new topic, generate help, save,
close, reopen: everything seems to work correctly
I'm sure I've missed a few things I've tried, but that's the
bulk of them. Anyone have any ideas how I can fix this issue?
TIA!
