When I shut down Premiere Elements 15, the hour spins for a few seconds after the program closes and I get an error in the windows 10 log that says Premiere Elements 15 stopped working.
Source
Adobe Premiere Elements 15
Summary
Stopped working
Date
11/11/2016 2:24 AM
Status
Report sent
Description
Faulting Application Path: C:\Program Files\Adobe\Adobe Premiere Elements 15\PremiereElementsEditor.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: PremiereElementsEditor.exe
Application Version: 15.0.0.0
Application Timestamp: 57cd94f4
Fault Module Name: MSVCR120.dll
Fault Module Version: 12.0.40649.5
Fault Module Timestamp: 56bc00d3
Exception Code: c0000005
Exception Offset: 000000000003c373
OS Version: 10.0.14393.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 267b
Additional Information 2: 267b2667622389525d840a701e510a46
Additional Information 3: da38
Additional Information 4: da380d594bf158cf32a5eb9547c0ed4a
Extra information about the problem
Bucket ID: a1f2426fc39ffc118aa44ac00547a957 (120566877068)
I ran sfc /scannow, and no files are corrupt.
Has anyone seen this before?
Bill Byrnes
Hi Will,
Thanks for posting on the Adobe forums.
Please try the following steps:
Sandeep
Thanks for trying to help, but this did not work. Same problem.
Bill Byrnes
Did a quick test today - just opening project, made two splits and deleted and removed hole and saved and exited.
No crash.
But viewing log there is a crash file from Premiere that might be of interest for the crash I had.
Seemed extensive with stack info and stuff.
But don't know where to post such long files?
That previous above was only from event viewer in windows.
Exactly the same I've got - not while running, just when exiting.
So I think Adobe need a report on this - but don't know how to report - even asked the question earlier without respone.
I will try and repeat, but basically I just cut out some video and deleted hole, and I also have some still images last.
Just the very first attempt, so nothing lost of value - but would be good if attended to by Adobe.
Here is my report from a week ago
Log Name: Application
Source: Application Error
Date: 2016-11-06 18:46:18
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: LarsMusik-PC
Description:
Faulting application name: PremiereElementsEditor.exe, version: 15.0.0.0, time stamp: 0x57cd94f4
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
Exception code: 0xc0000005
Fault offset: 0x000000000003c383
Faulting process id: 0x1158
Faulting application start time: 0x01d23816a37d92c4
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Elements 15\PremiereElementsEditor.exe
Faulting module path: C:\Windows\system32\MSVCR120.dll
Report Id: eb18b172-a448-11e6-a1c2-a4badb035e47
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2016-11-06T17:46:18.000000000Z" />
<EventRecordID>47132</EventRecordID>
<Channel>Application</Channel>
<Computer>LarsMusik-PC</Computer>
<Security />
</System>
<EventData>
<Data>PremiereElementsEditor.exe</Data>
<Data>15.0.0.0</Data>
<Data>57cd94f4</Data>
<Data>MSVCR120.dll</Data>
<Data>12.0.21005.1</Data>
<Data>524f83ff</Data>
<Data>c0000005</Data>
<Data>000000000003c383</Data>
<Data>1158</Data>
<Data>01d23816a37d92c4</Data>
<Data>C:\Program Files\Adobe\Adobe Premiere Elements 15\PremiereElementsEditor.exe</Data>
<Data>C:\Windows\system32\MSVCR120.dll</Data>
<Data>eb18b172-a448-11e6-a1c2-a4badb035e47</Data>
</EventData>
</Event>
Slightly different version of my MSVCRT120, but sure it's same error since just 0x10 bytes offset away.
So not dependent on redistributable, as I see it.
Plausible cause destructor in editor cleaning up resources using an invalid pointer to an object.
