Dear everyone,
I have one user, on his machine (Windows10 on a i5 skylake Lenovo Thinkpad Yoga + PS CC14) AM code executes awfully slow.
For example, this takes 0.04s on my old machine and 20s on his
var ref = new ActionReference();
ref.putEnumerated(charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
var appDesc = executeActionGet(ref);
Does anyone know what could be the reason?
Sergey
Might depend on the number of Fonts he has installed, or stuff like that.
As a rule (and when possible! which is not always the case) prepend the app descriptor get with the prop you're interested into, so that you're retrieving that only, e.g.
// DO
var ref = new ActionReference ();
ref.putProperty (stringIDToTypeID ("property"), stringIDToTypeID ("interpolationMethod"));
ref.putEnumerated (stringIDToTypeID ("application"), stringIDToTypeID ("ordinal"), stringIDToTypeID ("targetEnum"));
var interpolationDesc = executeActionGet (ref);
var theInterpolationMethod = typeIDToStringID (interpolationDesc.getEnumerationValue (stringIDToTypeID ("interpolationMethod")));
alert (theInterpolationMethod);
// DON'T
ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
var applicationDesc = executeActionGet(ref);
var theInterpolationMethod = typeIDToStringID(applicationDesc.getEnumerationValue(stringIDToTypeID('interpolationMethod')));
Hope this helps!
Davide
Thanks Davide!
I need to get an object
var curToolOpt = appDesc.getObjectValue(stringIDToTypeID('currentToolOptions'));
And If I understand correctly, I can't make this faster than getting the whole 'capp' thing
In this case you need to use "tool" to get "currentToolOptions"
ref.putProperty (stringIDToTypeID ("property"), stringIDToTypeID ("tool"));
var appDesc = executeActionGet(ref).getObjectValue(stringIDToTypeID("currentToolOptions"));
Thanks, SuperMerlin, exactly what I need!
May I ask you, how can I find certain property stringID? Like with tool in this example? Because I have some other objects I'm getting from 'capp'
Try the one that should work first if not you have to experiment with other values.
I'm sorry I don't think I understood. The one that should work...?
Ah, I got it. Sorry for spam!
