Hi everyone,
I decided to buy a new monitor for my pc but I can't decide which one will better cooperate with After Effects.
Currently I'm using Samsung S22C300H 21,5 inch but all windows/panels are too small and navigation between them is very problematic and slowdown my work.
Don't know which monitor will be better to choose.
- 27 inch with resolution 1920x1080p (for example: ASUS VC279H or Samsung S27F350)
or should I choose:
- 25 inch UltraWide FHD IPS with resolution 2560 x 1080p - (eg LG 25UM58-P)
Which one do you recommend? Unfortunately I don't know much about monitors, there features [Frequency/Image Brightness/Image Contrast Ratio etc].
I'm also planning to use "monitor arm" later so I will need monitor with VESA mount. [+ HDMI port of course].
Thx for help.
That's a tough choice. Probably the ultrawide.
Up
I use two ultra wide LG monitors at my full-time job. I like them a lot.
But what do you think, one ultra wide would be enough to work on?
It all depends on whether or not you like to be cramped when you work. Personally, I INSIST on having two monitors.
I have two ultra-wide monitors at work. Four full HD monitors at the freelance studio. So, no I don't think one is enough.
That being said, one ultra-wide is better than one regular one.
If you had to work just on one monitor which one would you choose? I can't afford to buy now two monitors. 😕
or
- 25 inch UltraWide with resolution 2560x1080p
You don't have to work with just one. You can a buy a new one and keep using your old one also. I used to work with a 22 inch and an older 17 inch until I bought a 27 inch ips and now I use that with the 22 inch and a 22inch pen display as well. and the 17 is collecting dust in the closet. Soon I wiil get second 27 inch or maybe a 32 inch. You don't have to have identical monitors to use two or three or four. If you have a working monitor use it as a second.
You are looking for a new best budget monitor in bd and also you are in confusion about which monitor would be great for you. If I suggest you, I would say you can go for the Asus brand. It has lots of models and the features are also very unique.
My guess is he's already decided which monitor to buy.
This thread is from 2016. 🙂
Love that Andrew LOL.
