Script for creating texture patterns
Guest
Nov 04, 2016 Nov 04, 2016
I would like to know is it possible to create a Photoshop script that can create texture pattern according to a mathematical formula?
If it is possible, please provide me with materials where to start to learn creating such scripts with examples if possible.
Take this website as a reference to get my point:
Textures.js
Jen
Actions and scripting
2.9K
Community Expert , Nov 11, 2016 Nov 11, 2016
Here's using the Deco Fill script, which has sliders to adjust some of the pattern placement:
Make a patter:
Under the Edit menu, select "Fill" and use Pattern for contents, and click on the Script box. Then Select the type of fill you want from the drop down list.
Click Okay, and the next dialog box will appear, where you can adjust the pattern's placement:
When you're happy with the placement, click OK:
Adobe
Enthusiast ,
Old Photoshop versions has PixelBender. But it's no logner supported.
You can write you own filter plugin in C++ find Photoshop SDK. There are examples. You can use Visual Studio. But this is more hard than script. But it can be really fast and it is real filter which you can apply on Smart Objects. It looks like this: https://scontent-frt3-1.xx.fbcdn.net/t31.0-8/13923292_1302261026470379_7817625681848121845_o.jpg
Or you can use HTML panel where is running chrome and use Canvas and already writen javascript libraries. It's maybe a bit dirty solution but it should be more easy. Depends what you want achieve.
Nov 06, 2016 Nov 06, 2016
Yes, you can create textures or patterns with extendscript. you just need to figure out what you want to do - what type of pattern. A good starting point is the Deco fill scripts. you can create your own custom patterns then change the parameters using the UI in the script. I went a bit further with this script and modified it so that I could apply the color of the base image to the pattern and have it also affect the rotation of the pattern:
You can also create other scripts. The main thing is just to have a loop that repeats some pattern. For example, I just made a script that makes a dot, but varied the color of that dot and moved placed it differently with a mathematical formula.
Guest
Can you post a script example please, so I can analyze it and try to build one myself according to the provided example?
Also, is it possible to implement a certain filter value in a script and control it with a html slider?
Jen
Make a patter:
Guest
Nov 12, 2016 Nov 12, 2016
Not a well solution as I expect, but will be enough to experiment with.
Thank you,
Jen
Contributor ,
Chuck UebeleCan you share your script with us? I found it very interesting and very useful
Which script? My last post shows the Deco Script feature that is in Photoshop. Some of my previous examples were just scripts that I wrote for myself to play around with images.
Contributor ,
About that! I confess that I do not know this feature in Photoshop ... I imagined that it was a script of yours.
No this is a feature in Photoshop that everyone has. I was introduced in CS6, and in PS CC an improved UI was created. I did have a little hand in helping with that, as I created a UI for the one in CS6, but it didn't have a preview. The engineer who created the deco scripts, like part of my UI and used it for Photoshop's:
My original script still works:
Scripted Fill UI - Photoshop CS6
Contributor ,
Nov 13, 2016 Nov 13, 2016
Congratulations on the script, thanks for sharing
