Hello!
I have tried to see if I can find a solution for this, but I can't find.
Every week I get a list of tv-programs in a word document and that comes in a newspaper.
First it is the time and then the program name and between them is a 9 mm tab.
Is there a way to automatically add the tab?
Your invisible characters aren't showing. What is coming in now?
You can use GREP in a Find/Change since it follows a pattern and then save the search to re-use.
Do you mean add a tab character or set the tab marker at 9mm? That would be apply a style.
Make and save a find & replace GREP query. Later it is a single click to change everything.
I want a space between the time and the name of the tv-program
Sorry, I am so bad at explaining in english.
Now I have to take one row at a time and press tab to get the space.
You didn't answer the question about what you are getting now. Turn on Hidden Characters and post another screen shot.
If you have a tab character and want a space or vice versa, do a Find/Change.
If you have a tab character, then set it so that you have consistent spacing.
Does that answer your question?
Find: ^\d{2}\.\d{2}\K\h
Replace by: \t
Sorry for a very late reply. Yes like this. This does almost what i want, but it takes every other line
