Usually when I import photo there is a destination option on the right within the import dialog.
Images; my import menu (without destination option) vs old import menu (with destination option)
What has happened!? Help needed!
This is a known issue in Lightroom CC 2015.6.1/Lightroom 6.6.1 or earlier.
Solution:
To avoid the compatibility issues on macOS 10.12 (Sierra):
- Update to Lightroom 2015.7/Lightroom 6.7, or
- Remain on your current Mac OS X version and do NOT update to macOS 10.12 (Sierra) if you are running Lightroom 5 or earlier.
You can read more here:
https://helpx.adobe.com/lightroom/kb/lightroom-and-mac-os-sierra.html
You need to select a source first
Right click on one of the headers and select Destination.
No need to select a source first.
I have the same problem. It has happened since I updated to Sierra on my Mac
The answer has already been stated in this thread by Just Shoot Me​
I'm not so sure that is the problem.
More likely it's the known issue which I sent a link to above.
And that is based on the statement from kereru11 that it happened after Sierra update.
Thommy
No mention of the Destination section missing in that link you posted.
Opps there is a mention of it for LR 6.6.1 and previous versions in that link but the fix is to right click and select those options for display
That worked - the right click. I have Lightroom 5 and I now have the destination file back. Thanks
Solution:
I do have Lightroom 5 but the right click worked so thanks. I now have my destination file back
