My projects (1080p) are between 2-10 minutes long and they contain the same template as following:
-Particles emitter (Particular) which emits from outside of the screen (do I need to trim that in some sort so that AE will not process what's going outside?) that reacts to music (Sound Keys) + Camera layer.
-4 Audio Spectrums that react to music (Sound Keys) which are in a comp within the main comp.
-720p footage duplicated also in a pre-comp inside the main comp, also reacting to Sound Keys.
-Looped GIF as background
-Still image
-Music track
My specs:
i7 5820k
16GB DDR4 2133MHz
GTX 780TI
GA-X99 SLI
I've got 2 SSD's , one that the system and AE runs from and another for disk cache and conformed media cache. also 2 regular hard drives.
While export rendering CPU is on 23% and RAM on 55% workload, so i'm guessing improving those won't help.
Export rendering takes about four hours for each composition, I would appreciate recommendations on optimizing rendering time.
Weren't we over this already? Everything seems perfectly normal, given that you use a complex particle simulation and time-remapped footage, which causes redundant calculations for sampling multiple frames and blending them...
Mylenium
